Post Info TOPIC: Truma Air cons
Truma Air cons
Hi, I'm looking into air for my Jayco Freedom poptop 18' single beds. I'm not sure if it;s fitted with a H frame for rooftop install. How can I tell? Also Truma under bed aircons. Are they any good. One service agent had a different name for them. So I'm asking the ones who know. Cheers Rob.
The only way to accurately tell what is under you roof skin unfortunately is to remove it.
I believe you should reconsider placing any unit on a pop-top roof as not only will it become (too?) heavy to lift it will dump condensate water on roof that will severely test you roof seals. Possibly giving you an unwanted shower if not careful when lowering roof.
There are some portable air conditioners and coolers available out there that do a good enough job when the heat is on.
The question to ask yourself is how many days are you going to need air-conditioning any way. In the last year we have used our (Ibis) unit no more than five or six evenings. Unless suffering severe respiratory symptoms consider using a fan and spending really hot days in a swimming pool or shopping centre with air-conditioning.
Hi Romany,
Possum again speaks many words of wisdom! Use a portable unit.
My Discovery has an under bed air conditioner - it rumbles a bit on start but I can sleep through it, is noisy to those outside but in the van it is good.
The outlet/control panel is at the end of my bed, above where the TV, RCG & other power bits are - the cupboard below comes in handy to rest my tootsies on when I stretch out.
NOW, would I fit an air conditioner to a previously unairconditioned van? NO!
Sure if the roof was strong but I suspect yours is like mine, it serves only limited purposes - it keeps the weather out, is somewhere to mount the TV aerial & the roof vent - NOTHING ELSE! And any weight you add to the roof has to be lifted - BY YOU, unless you have those air lifters.
As to adding the under bed unit, there is too much effort required - one would almost have to wreck the walls to feed the pipes.
Next option, next van - be it new or second hand, ensure it has an air conditioner in it.
Hi, I've seen the portable units fitted into the cupboard next to the sink and vented into the front boot. The water is drained through a hole in the floor. The boss doesn't want to loss the cupboard space. Truma units are what we looked at. Want to know if they are any good. Cheers
I did my 15ft poptop with a portable unit.  It will bring the air down to 23 degrees (on a hot humid day) in about 30 minutes.
All up cost about $400.
Cheers Pete
Pete, Beautiful installation (too good to be done by any Manufacturer).
Thanks Pete.
Hi again Romany,
Are Truma air conditioners any good? YES - as I said ours is built in. It vents through the floor through holes some 100mm diameter - in front of the RHS wheel.
Later this afternoon we arrived at Sarina & were totally soaked through by the time we set up (the humidity must have been approaching 90% - without it raining). Pat asked if I wanted the air conditioner on, what a silly question!! So for ten minutes we "dried out" in cool comfort!
Pete's unit looks good - the idea of the month?
Thanks Warren. I got on to a place in Mackay that will fit a Truma but they don't like them. So the Question. Rob
Romany Have you seen this; rvdaily.com.au/how-climate-change-could-be-good-news-for-portable-aircon-in-your-rv/
Cheers Pete
What wattage is that unit you put in, we have a 17ft poptop  ,and looking at the air-con site there are about 6 different models
Hi Romany
Yes they are. I fitted a Truma Climaster and with a bit of extra ducting ended up with 5 outlets at floor and roof. Great on cooling not quite as good on heating. Pm if you want more info and some pics.
ciao
