Post Info TOPIC: I'll stir it up...
Status: Online
I'll stir it up...
Would this be a problem you think?
Plenty of room at the rear to load with water! & a visible licence plate! Hope that is a Q7 at the other end!
No, as long as it's full of blown up balls.
Naaah, she'll be right!
Looks to me that they have a heavy tow ball weight with the beds and wet area up front,so maybe the box is an equaliser?
KJB
In that case, it could turn into  a " horizontal flywheel".....
-- Edited by KJB on Monday 10th of February 2020 04:28:33 PM
KB
Perfect spot for the generator & the outboard & the Weber & all the blocks of hardwood for the camp fire . Maybe the chainsaw will fit too , all sorted ;)
That power lead is all piled up and could burn out. Looks like grey water from the three outlets toward the rear will just run out on the ground. I reckon it is over weight too. Plus, the tug is not suitable for such a big van.
One more thing, no windows open for when the portable gas heater is in use.
No problem nice looking unit, as long as they leave the stabilizers down.
Must be a V6, 3 pipes out one side, I presume the other 3 are out the other side.
I can't really see enough of the bent pipe (or what appears to be that) out of the box (near side rear face) but hopefully not an exhaust for a generator.
Cheers Ian
Cheers - Ian
I slowly realise as I get older that I am definitely NOT the fastest rat in the race.
Also the older I get the more I realise I do not know.
Cheers Ian
Agh! You dumbo Ian! The bent pipe is the white directional arrow to move back a photo. nono
Cheers - Ian
Great observations and yes they camp among us.
Jay&Dee
Mobi Condo wrote:
Cheers Ian
 It flashes when they reverse......biggrinbiggrin
Chris & Sharyn.
Tea Gardens. NSW.
I might be going blind but I cant see any number plate on the van is this just a mock up ???
Not much room for an awning either, Landy
Cheers Craig
That's right Craig I don't think the boys in blue would be to impressed with not being able to see both indicators unless your directly behind either.
