Post Info TOPIC: Foxtel IQ4 Box
Foxtel IQ4 Box
Hi all,
I will be hitting the road again soon and plan to take my IQ4 Foxtel box with me. The new box requires 2 cables connected to the satelitte to work fully but am told it will still work with one cable but you will not be able to record.
My question is will a splitter with one IN terminal with multiple OUT terminals work? MY hope is to have the one cable IN from  the satellite then 2 cables from the splitter OUT terminals into the IQ4 BOX then a 3rd cable from the splitter OUT terminal into the VAST system.
See picture below. Will this work?
Col
(Picture of my beloved Molly (2003 - 2016) who loved the travels as much as I do. RIP old girl. Gone but never forgotten).
no you need 2 cables as you are using the horizontal and verticle part of the lnb
blaze
KFT
G'day Col
The ideal setup for what you wish to achieve is 2 cables from a dual LNB to your van. Those two cables then need to be connected to the V & H terminals of a satswitch (see picture) you can then connect 2 cables to your IQ4 and one to your VAST box and it will all work just like it does at home.
I have done many installations in caravans this way and it is a proven method. I use it in my van too.
The pic you have posted is not intended for what you wish to achieve.
Hope that helps
Frank
Avagreatday.
Hi all; As KFT has said you could use one of those multi switchers and that will work. Another way is to use a quad LMB and run 4 cables, 2 cables for you foxtel, 1 cable for your vast receiver and the other would be used as a spare or for alignment of your dish.
Thanks KFT and Valiant81 for your replies. This has always been a great forum for information and all one has to do is ask.
Thanks again.
-- Edited by cjt55 on Sunday 9th of February 2020 06:38:56 PM
Col
Sorry blaze, I missed thanking you too.
Col
I have successfully used the set-up in the pictures attached without any splitter.
