Post Info TOPIC: Small single arm davit
Hi again all, I am chasing ideas on installing a single arm davit on the back of my van's rear bar (load capacity of 160kg). Has anyone got one and if so would they share the design or manufacture with me.. I am thinking of unloading and loading the twin spare tyres etc..
KB
Gooday,
 Suggest you rephrase your question with a better or more commonly known name for what you are looking for, I had never heard of such a thing, but after Googling I discover it is in effect a form of hoist or lifting device.
Bliss On Wheels
Bliss the OP used the correct term "Davit", it is a specific type of hoist - often used on ships to raise and lower life boats - with no driven slewing or luffing motions, (i.e. fixed reach arm).
LOL. Yeh, I picked up on thatoo.  Pretty specialised terminology. My bet is OP has worked in shipping related industry or Confined Spaces.
Sta
Branchie,
I used to use a simple boat winch on a pipe with a folding out rigger. Yep, probably not understood by some.smile
Any way I welded a 300 mm bit of 40 mm steel gal pipe onto my Jerry can frame and put the upright with the winch attached into that. It could spin freely in the 40 mm pipe and the winch could lift a 35 inch tyre that was around 40 kg.
Retired plumber & Plumberess
 2004 Toyota TD LC
A'van Tayla 17'6" Caravan
Many thanks mate, thats sounds simple enough to install/weld.. I am guess the other guys were bank manger sin their previous work life, and not understanding of what i meant..
KB
Thanks Guru....
KB
