Post Info TOPIC: clevisl hooks
RE: clevisl hooks
Permalink Closed
Thanks Chris/Sharyn.....I trust that this information was easily found? Cheers
Permalink Closed
Thanks, Chris, Sharyn, two things out of this, 1 -that the "D ", more probably bow shackle will fit over the tapered latch hook more easily than bare end of chain. and 2 -has anyone actually truly tried to check or measure the chain length to see that it keeps the drawbar off the bitumen/concrete in the worst case scenario ? or like me, just a good I hope edumacated guess
Cheers Craig
Permalink Closed
Without wanting to start a spit fight,very few of the towing setups that I have seen would keep the drawbar off the road should the trailer detach.Whilst the theory is good,if the van comes off the hitch,the van drawbar will run under the car's towbar,thus reducing the distance between the point where the chain is welded to the van's drawbar,and where the chain attaches to the car.The drawbar will thus hit the road,as very few chains are shorter than the distance from the hitch point to the road.The bigger the distance from the hitch point to where the chains attach to the drawbar,the bigger the problem.Breakaway systems are useless unless the van leaves the car and actually pulls the pin to activate the brakes,whilst the 7/12 pin plug is likely to become disconnected when the drawbar drops to the road,rendering the electric brakes useless too. I have recently been playing around with a short piece of chain that goes from one safety chain to the other,over the towbar,just behind the DO35 hitch,so that if the van becomes disconnected,the drawbar still is 300mm off the road.Work in progress.Cheers.
Permalink Closed
The Travelling Dillberries wrote:
Perhaps these pics will help, selected from the internet.
Hammerlock, used to join chains.
Clip a D shackle in, very easy.
 Many thanks to the Travellers and to Craigs comment on using a Bow Shackle replacing a D shackle.
With the pics and the description, myself and many others can now see the information that I was requesting. How simple!
It looks like a good idea and I think that I have actually seen some of those hooks hanging from some tow bars from time to time.
Ivan
Permalink Closed
So Yobarr, the theroy is that your top chain piece will still allow an almost jacknife reverse without pulling the chains off the drawbar or coupling, which is likely to happen if they are shortened enough to stop the thing hitting the ground?
Cheers Craig
Permalink Closed
I might be missing something here, but what's wrong with just using the supplied and legal "D" shackles. Its not like you unhitch the van at every intersection, seriously it takes a minute to connect them.
Permalink Closed
That is exactly right Craig,and is the reason that I am experimenting with the cross chain.It depends a lot on how far apart are the points where the chains are attached to the car. The further apart they are,the bigger the problem,but a lot depends on how far back from the hitch the chains have been attached to the van.....the closer the chains are to that hitch point,the lesser the problem.The cross chain allows for more slack in the safety chains,but I will get my engineer to certify everything anyway.So far,so good! Cheers
Permalink Closed
Hooks are much quicker and easier to use,and can be connected and disconnected with one hand,whilst the hammerlocks mean that nobody can "borrow" your hooks or shackles. They also can be used if you simply want to lengthen your chains a bit.Cheers
Permalink Closed
 It may be just a male thing.
Many of us like to potter around and 'fix' or 'improve things'.
In this case maybe to make another aspect of hitching & unhitching just a little bit quicker & easier.
I could post a list of the vast range of things like this that I have done to 'improve' things on the van over the years. But I wouldn't like to risk the wrath of others by going off topic. LOL
Permalink Closed
Cupie wrote:
 It may be just a male thing.Many of us like to potter around and 'fix' or 'improve things'.In this case maybe to make another aspect of hitching & unhitching just a little bit quicker & easier.I could post a list of the vast range of things like this that I have done to 'improve' things on the van over the years. But I wouldn't like to risk the wrath of others by going off topic. LOL
 Very wise decision Cupie....there seems to be a couple of sensitive souls around! It is human nature that,in the course of any conversation,one topic touches another,and suddely we are 'off topic'.Simple solution is to cease reading imediately you think that someone has gone 'off topic',surely? You could perhaps start another thread along the lines of "improvements I have made".....then you'd be safe? Cheers
Permalink Closed
 Hi Cupie,
You could always just start another topic which could include anyones modifications and improvements with vanning.
This topic could stay independent of the others.
Or we could all use this sub forum.
https://thegreynomads.activeboard.com/f593698/hints-tips-and-great-ideas/
-- Edited by Iva Biggen on Wednesday 27th of November 2019 01:00:08 PM
Ivan
Permalink Closed
Iva Biggen wrote:
 Hi Cupie,
 What a good idea ...  LOL
If you have a look at the first post on that sub forum (23/April 2013) you might get a surprise.
Must not have been very interesting .. Only 1 reply (from Dunmowin) from 7595 looks!
Permalink Closed
 I chose to present the photos to circumvent the rediculous toing and froing that was in progress.
I have also seen these safe lock hooks in industry fail in that the safety catch bends and is therefore ineffective.
I would not use this system, preferring the simple d shackle rated to the correct capacity.
I also commend the testing and theory that Yobarr is doing. It's also amazing to see what lengths we go to to prevent a worse situation that in actual fact is not a medium to high risk  issue. Guess it keeps us old yobbos occupied
Chris & Sharyn.
Tea Gardens. NSW.
Permalink Closed
Cupie wrote:
Iva Biggen wrote:
 Hi Cupie,
 I just had a look at your link to a post way back in 2013.
 Many of us newbies were not members then...well at least I wasnt.
I generally read and contribute on a mobile device and as such I really can not read your cursive text in that post. That text maybe the reason why only one contributed an answer.
I do know that back then many of us used computers as opposed to small devices which are more the norm today.
Computer screens may be a bit clearer to at least my old eyes but I am in my van most of the time so it is the mobile which is my device of choice.
The sub forum is a good resource.
-- Edited by Iva Biggen on Wednesday 27th of November 2019 08:13:40 PM
Ivan
Permalink Closed
 Seeing you quoted me I will once again say, thank you for clarifying what was an ambiguous description of the method of using differing pieces of equipment.
Cheers and thanks again.
Ivan
Permalink Closed
yobarr wrote:
Without wanting to start a spit fight,          very few of the towing setups that I have seen would keep the drawbar off the road should the trailer detach.             Whilst the theory is good,if the van comes off the hitch,the van drawbar will run under the car's towbar,thus reducing the distance between the point where the chain is welded to the van's drawbar,and where the chain attaches to the car.The drawbar will thus hit the road,as very few chains are shorter than the distance from the hitch point to the road.The bigger the distance from the hitch point to where the chains attach to the drawbar,the bigger the problem.Breakaway systems are useless unless the van leaves the car and actually pulls the pin to activate the brakes,whilst the 7/12 pin plug is likely to become disconnected when the drawbar drops to the road,rendering the electric brakes useless too. I have recently been playing around with a short piece of chain that goes from one safety chain to the other,over the towbar,just behind the DO35 hitch,so that if the van becomes disconnected,the drawbar still is 300mm off the road.Work in progress.Cheers.
 Alas with many of your statements in other topics Yobarr you always assume in your comments that most of us do not know what we are doing.
Could you just for once assume that many of us know the regulations and not group us in the worst situation.
Thank you
edit; I tried to highlight what you said but it may not be as clear as I hoped.
-- Edited by Iva Biggen on Wednesday 27th of November 2019 08:29:04 PM
-- Edited by Iva Biggen on Wednesday 27th of November 2019 10:39:42 PM
Ivan
Permalink Closed
 Just to clarify for all of us Yobarr could you please give all of us a link or a way of identifying your consultant engineer that has approved or will assess and susequently approve these modifications.
Thank you
Ivan
Permalink Closed
Thank you
 I am sure that anybody capable of accessing Google would have little difficulty in finding an suitable engineer in their local area.Cheers
-- Edited by yobarr on Wednesday 27th of November 2019 09:03:57 PM
Permalink Closed
Read this group of posts for facts.
https://thegreynomads.activeboard.com/t57042661/using-a-clevis-slip-hook-on-safety-chains-legal/
yobarr I like your comment "without wanting to start a spit fight"  --- since when. That's all you appear to do.
Permalink Closed
 Yobarr
From your post above.
I will get my engineer to certify everything anyway.so far,so good! Cheers
You are the person that is informing us all that your safety chain set up is approved or will be approved by the various state authorities so cough up mate and prove it.
This is directly related to the question the OP asked whereby you said clevis hooks werent approved but your method is.
You, at the very least, owe it to him or her to provide proof.
I would just like to see that from an authority other than a truck driver.
While you claim that all people in authority may not be fully conversant with regulations when they intercept you on the road I personally would like to offer more than the explanation and excuse that a truck driver on a caravan forum said these safety chains comply.
Do you see where from where I am coming.
To my knowledge all van manufacturers just use D Shackles to the tow bar..
Thank you
Ivan
Permalink Closed
There would be many of us that would like to see the engineers approval.
It would be a pretty poor excuse if offered to a transport inspector or police although they would get a laugh about it after the fine and penalty was issued.
I will stick to D shackles until I see proof of compliance.
Nothing worse than the thinking you are right and an argument ensues that the motorist will never win.
Rob
Rob
Chairman of the Bored
