Post Info TOPIC: Anyone know how to.....
Does anyone know how to remove the end of a ignition key that broke off inside the ignition please?  The car is a Kia Rio wagon. Thanks June C
I have picked them out with a sharp scriber by using the point to jag into the metal of the key tail but if it has broken off too far down you may need the services of a locksmith. There are mobile locksmiths around depending on where you are at present.
Greg O'Brien
A rare earth magnet, maybe...?
Get a fine tooth hacksaw blade, and grind the back side down so that you have a fine, narrow snout with teeth left. Make sure that the teeth are pointing backwards. Slide the blade under the key, let the hacksaw teeth bite into the key stub and gently pull it back.
Probably a youtube video giving some tips.
Thats not your KIA left running at the Klemzig Obahn is it ?
No thank goodness.  Thanks for your reply June C
Good suggestions, thank you for all those great ideas June C
There are very fine pointed tweezers (the type used by eye surgeons) they have a positive grip as do surgical clamps. I know these are normally used by Drs and Nurses but some people (like me) do have them in their First Aid kits.
just for future reference has the problem been fixed and if so how?
Ive called a locksmith . On these occasions.
