Post Info TOPIC: Casale 2.2 kg washing machine
The machine stopped working.  Not overloaded but washed the bath mat.  Maybe too much fluff.  Had to empty most water out by hand.  A lot of fluff in bowl.  How do i check if drain  is blocked.  Cannot see how to get machine out.  HELP
Noel Grant
Possibly would help if we had a photo of washing machine along with make of caravan.
Has the machine been used regularly, is the outlet blocked out side, extended drain hose maybe blocked, run some water though it
Our Concept has panel in fornt of washing machine with a hand full of screws to remove then disconnect the water, drain pipe and power lead first and then man handle it out.
I would take the drain pipe off the washing machine first check to see if it is draining first ok.
Just some ideas.
