Post Info TOPIC: Fridge relay
Fridge relay
Any idea where I can get a replacement relay for a Dometic 4605. One in it at present is a Raytex LD2AU-12p 40amp. I tried S/cheap Jaycar and now onto Narva direct but having difficulty. Its the relay from the engine for the AES switch over to 12v. TIA Bas
 Are you sure that it is Raytex,as RAYEX Electronics is easily found via Mr Google? Cheers
Finger trouble, yes its a Rayex and yes its on Google available from Rayex OS with a MOQ of 200 units. I offered to buy 5-10 to no avail.
According to Narva the part number from Rayex corresponds to a 5 pin relay but this is 4 pin. I have sent photos to Narva and they are a little stumped so I will send more photos of the relay without wires connected as they have requested to see the terminals.
Is asking Dometic not an option ?
I checked Dometic spares but its not listed there. I may email them. Thank you
just take it a auto electrician he will be able to see what type it is and match the correct part. As there is a lot of different types of relays for different outcomes that can be done .
Fixed: Narva tech dept. 5 pin relay but only 4 terminals used.
