Post Info TOPIC: Adding 2 stroke oil in Diesel
Hi ..
Picked this up on a Patrol Forum.
For me, it is of interest only as I have a petrol engine.
It was suggested earlier on the thread, that in the older engines (non CRD) where petrol had inadvertently been put into the tank, after draining etc, a dose of 2 stroke was a good precaution.
Do any of you 'oiler' drivers use 2 stroke as an additive?
"Due to the pollution control measures of the EC diesel-oil is nearly sulphur free and contains up to 5% of bio-diesel. Sulphur has the property to grease the high pressure injection pump and the injectors. Without sulphur, the reduced greasing property of the new diesel has already shown negative impacts on the long-term stability of the injectors and the high pressure pump.
The pump manufacturers have tried to react by lining the moving parts of the pumps with Teflon or other suitable material. However, the long term stability is still not achieved as with the old (sulphur contained) diesel.
The engine-research centre of a well known German car manufacturer has conducted some long term tests of diesel additives to find out whether any one of them will have an impact on the long term reliability of the diesel engine components. This introduction to explain were my information comes from.
The results of this research:   ....
Any diesel additive of any manufacturer presently on the market is not worth the money!
BUT: 2-stroke oil, which we use in our motor saws, lawn mower or in 2-stroke motor engines has shown to have an extreme positive impact on diesel engines, if such 2-stroke oil is added to the diesel in a homeopathic doses of 1:200. In practical terms: 0,300 litre of 2-stroke oil into the 70L diesel tank. The 2-stroke oil will be absorbed by the diesel (emulsion) and grease every moving part of the high pressure pump and the injectors.
Besides this, the 2-stroke oil will keep the diesel engine clean, as it burns cleaner as the diesel itself.
In other words, the 2-stroke oil has a much lower ash-content as diesel, when burned. This proven fact delays the DPF (diesel particulate (soot) filter) to clog, and the "burn free" process of the DPF will be much less.
One more piece of information:
In Germany we have to present our cars every 2 years to the TUV -Technical Supervision Organisation - who will check, amongst other things, the pollution of petrol and diesel engines.
The measured cloud-factor of a diesel engine without use of 2-stroke oil has been 0,95.
The same factor with the use of 2-stroke oil has been 0,47 - reduction of nearly half of the soot particles.
Besides this, the use of 2-stroke oil in the diesel will increase the mileage by 3-5%.
and more :-
You may all know that Mercedes Benz have conducted in 2007 a long distance reliability test with a number of Mercedes E-Class 320 cdi from Paris to Beijing.
Due to the fact that the diesel quality in East European Countries, Russia and China does not meet the DIN requirements, and Mercedes did not want to take the risk of their engines to flop due to lousy fuel, the total tour has been accompanied by diesel tanks to re-fuel the E-Class cdi's.
Selected members of the Mercedes clientele could apply to participate in selected parts of this test-tour, and advocates and notaries had to certify the correctness of this long term reliability test.
Although Mercedes does not like it published or made public, it is a fact that the diesel-fuel used for this test did contain 2-stroke oil to grease the high pressure pump components and to keep the engines clean during this marathon.
Why our car manufacturers do not officially allow the homeopathic addition of 2-stroke oil to the diesel fuel has many reasons, mostly of legal nature. Besides this, which car manufacturer has any interest in excessive reliability of their engines? Their repair shops will have great problems.
Meanwhile the "2-stroke-oil to diesel" issue has attracted the interest of a number of Universities in Germany, as this 2-stroke oil has shown to have amazing properties if added in a small does to diesel fuel (1:200), especially the positive impact on air pollution, reduced fuel consumption and improved long term reliability of the diesel engine. The pro and con discussions will go on for a while. But as soon as an academic report has been published by one of our Universities, this will change very fast.
By the way:
All car manufacturers reject the addition of any fuel "additive" in their cars, and warn that guarantee MAY be affected. Nobody says, that guarantee WILL be rejected. 2-stroke oil in its properties is not an additive, as you add oil to oil if you "dope" you fuel with a doses of 2-stroke oil. The doses of 2-stroke oil in your diesel-fuel is very difficult to analyse, as every (chemical) analysis has the main function to identify substances which are harmful. But 2-stroke oil has proven not to be harmful at all, on the contrary!
Personally, I use 2-stroke oil now for many years in all of my diesel cars (my present business car is a Mercedes 320 cdi DPF Automatic). And I never had any problems whatsoever. "
no
blaze
ps diesel fitter by trade and experience
No, my mechanic puts in injector cleaner during certain services and that is all.
Onto my 3rd 3.2DID Pajero now, with previous 2 doing over 250k each without problems.
-- Edited by Rod Mac on Friday 2nd of August 2019 04:30:55 PM
Hi smile
Well I have maintained small mixed diesel fleets and never used it or any other additive in the tanks. Just good filtering and maintainance.hmm
Now looking at this statement "the diesel quality in East European Countries, Russia and China does not meet the DIN requirements" I might not disagree with it but what has 2007 diesel from those countries  got in common with Australia in 2019 ???? Not much I believe. no
It is amazing what you can find to justify things on the internet. But probably not doing any harm. Just do not believe those claims about any of it really and the DPF disbelief:
"The measured cloud-factor of a diesel engine without use of 2-stroke oil has been 0,95.
Besides this, the use of 2-stroke oil in the diesel will increase the mileage by 3-5%."
-- Edited by Jaahn on Friday 2nd of August 2019 05:58:12 PM
Cupie wrote:
Hi ..Picked this up on a Patrol Forum.For me, it is of interest only as I have a petrol engine.It was suggested earlier on the thread, that in the older engines (non CRD) where petrol had inadvertently been put into the tank, after draining etc, a dose of 2 stroke was a good precaution.
 Do any of you 'oiler' drivers use 2 stroke as an additive? .......................................................................................................
"Due to the pollution control measures of the EC diesel-oil is nearly sulphur free and contains up to 5% of bio-diesel. Sulphur has the property to grease the high pressure injection pump and the injectors. Without sulphur, the reduced greasing property of the new diesel has already shown negative impacts on the long-term stability of the injectors and the high pressure pump.The pump manufacturers have tried to react by lining the moving parts of the pumps with Teflon or other suitable material. However, the long term stability is still not achieved as with the old (sulphur contained) diesel.The engine-research centre of a well known German car manufacturer has conducted some long term tests of diesel additives to find out whether any one of them will have an impact on the long term reliability of the diesel engine components. This introduction to explain were my information comes from.The results of this research:   ....
Any diesel additive of any manufacturer presently on the market is not worth the money!                                 BUT: 2-stroke oil, which we use in our motor saws, lawn mower or in 2-stroke motor engines has shown to have an extreme positive impact on diesel engines, if such 2-stroke oil is added to the diesel in a homeopathic doses of 1:200. In practical terms: 0,300 litre of 2-stroke oil into the 70L diesel tank. The 2-stroke oil will be absorbed by the diesel (emulsion) and grease every moving part of the high pressure pump and the injectors.                   Besides this, the 2-stroke oil will keep the diesel engine clean, as it burns cleaner as the diesel itself.                    In other words, the 2-stroke oil has a much lower ash-content as diesel, when burned. This proven fact delays the DPF (diesel particulate (soot) filter) to clog, and the "burn free" process of the DPF will be much less.
One more piece of information:In Germany we have to present our cars every 2 years to the TUV -Technical Supervision Organisation - who will check, amongst other things, the pollution of petrol and diesel engines.The measured cloud-factor of a diesel engine without use of 2-stroke oil has been 0,95.The same factor with the use of 2-stroke oil has been 0,47 - reduction of nearly half of the soot particles.Besides this, the use of 2-stroke oil in the diesel will increase the mileage by 3-5%.
and more :-You may all know that Mercedes Benz have conducted in 2007 a long distance reliability test with a number of Mercedes E-Class 320 cdi from Paris to Beijing.Due to the fact that the diesel quality in East European Countries, Russia and China does not meet the DIN requirements, and Mercedes did not want to take the risk of their engines to flop due to lousy fuel, the total tour has been accompanied by diesel tanks to re-fuel the E-Class cdi's.Selected members of the Mercedes clientele could apply to participate in selected parts of this test-tour, and advocates and notaries had to certify the correctness of this long term reliability test.Although Mercedes does not like it published or made public, it is a fact that the diesel-fuel used for this test did contain 2-stroke oil to grease the high pressure pump components and to keep the engines clean during this marathon.                               Why our car manufacturers do not officially allow the homeopathic addition of 2-stroke oil to the diesel fuel has many reasons, mostly of legal nature. Besides this, which car manufacturer has any interest in excessive reliability of their engines? Their repair shops will have great problems.
Meanwhile the "2-stroke-oil to diesel" issue has attracted the interest of a number of Universities in Germany, as this 2-stroke oil has shown to have amazing properties if added in a small does to diesel fuel (1:200), especially the positive impact on air pollution, reduced fuel consumption and improved long term reliability of the diesel engine. The pro and con discussions will go on for a while. But as soon as an academic report has been published by one of our Universities, this will change very fast. By the way:
 I religiously use Activ2 Castrol 2 stroke motorcycle oil in my diesel,at 3mm/litre of diesel.Quieter at startup,more power and better economy......This oil is particularly effective in cars fitted with Denso injectors.Cheers
When we did our lap . I added a small amount . 200mm to 300l tank as the GM injector pumps did have issues . Dont use it now as we drive short trips . Either the distance or the oil made it run and start very smooth, economical.,
While I can understand the argument about the 2-stroke lubricating the fuel pump and injectors (although I've read it's more complex than this, and is only a benefit for certain types and makes of diesel fuel systems and not others), I'm highly dubious about the second half of the claim that it actually burns cleaner than pure diesel.
How many of us can remember going to Asian cities when all the motorbikes were powered by 2-stroke engines, and the clouds of smoke they produced! And I still remember having 2-stroke boat engines, and there's nothing anyone can say to convince me they burnt cleaner than today's 4-stroke ones!
But those two examples are petrol engines, so maybe diesel is different - right? Well, consider this. A small amount of oil does find its way into the combustion chambers of modern diesels already - it comes past the piston rings from the sump. My understanding is that this is seen as a bad thing by auto manufacturers because it raises the emissions they are trying so hard to reduce, and it can clog the DPF filters because it causes MORE ash, not less. That's why engines with DPF fitted specify a low SAPS oil, to reduce the effects of the DPF being clogged from the residue of burning even small amounts of lubricant oil.
As for the third claim that it increases fuel efficiency by 3-5%, now I think it's just going into the realms of the snake oil salesman, but I'm going to give the usual disclaimer that I'm not an expert on these things, just thinking aloud!
-- Edited by Mamil on Saturday 3rd of August 2019 02:58:46 PM
Yep to that.
Commercial diesel operators don't add other stuff to their fuel. There are good reasons why that is so.
peter
I have to agree with you Mamil. It's like back many years ago when I was a test driver in the automotive industry, we often had people making claims that they had bolted some other carburetor to a car and were getting large gains in fuel economy. Never mind that the manufacturer had spent large sums flow metering and testing various carbies to arrive at the best one and settings for that particular engine. If it were so easy that you could pull one off the shelf and get immediate improvements every manufacturer would be doing it. We put a few of these claims to physical test and not one of those we tested lived up to the claims and in fact were worse than the original specs. Hence I treat most of these claims with great scepticism.
Greg O'Brien
Yep plenty of them old carby had fuel pipes break away also, causing fires ! After 1000s of hours testing !! Toyota have recent issues with PDF . After many 1000 hours testing ., The oil gets burned like the diesel does . Btw its not the diesel that totally end up in
Oil . Its the carbon . A result of combustion . The old 2 stroke bikes run high oil content . Modern injected 2 stroke outboards are totally different . EPA keeps them in order .
 They certainly did - they banned their sale because of the pollution they cause and putting oil into a diesel is probably illegal for the same reason.
One of my Air Force Sargeants told me when I was only 18yo after spotting a bottle of upper cylinder head libricant in my engine bay "if the engineers that designed the engine thought it should be there they'd have designed it there as standard" Tony
 Unfortunately engineering is underpinned by accountants and their veiw of economics.
My experience is that older diesels benefit from adding the oil, my 35 year old Volvo smokes less on startup, runs smoother, quieter and is perhaps a little more pokey. Perhaps.
Not sure if it assists the diesel heater much as I suffered a string of issues after adding to the main tank. Probably coincidence, just sayin'.
Modern high pressure diesels get no benefit at all.
KJB
I have owned and or operated diesel trucks,tractors,earth moving equip. and cars continually over a period of 60 years and have never used an "additive" of any kind or worried which company supplied the fuel and I have never had a problem with any of the diesels. Just normal filter service/changes is all it takes - keep dirt and water out of the fuel system.
KB
A good mate of mine was a Caterpillar field service engineer and spent his whole working life with CAT. His advice to me when I got my first diesel was to always have clean oil, clean fuel and change the oil and filters regularly. His advice regarding additives was long and colourful and boiled down to DON'T.
More advice from him was, when working on cars was to always throw away used fasteners and replace them with new ones and to always use a good accurate torque wrench. It seems to work as my old Series III diesel lasted over a million km's and my current Td5 has over 400k km's on it. Neither car has suffered any failures apart from normal wear and tear (clutches, alternators, etc)
-- Edited by markf on Monday 5th of August 2019 01:59:45 PM
Mark F...
VK3KW
2010 Outback Campers Sturt
http://jandmf.com
Would say your mate was on the money Mark. Pretty much my sentiments.
Greg O'Brien
Diesel fuel has changed. Original additives have been phased out or reduced.
https://www.environment.gov.au/protection/fuel-quality/standards/diesel
I suggest you check the sale of 2 stroke outboards out !! The are NOT banned !! I some lakes or reserves they are !!! Same with ski or personal water craft in some water ways !!
l have a 1990 1HZ diesel motor now with 400 000 k's. Have been putting 330ml ( old engine oil flush bottles with long neck) mineral based 2 stroke oil per tank (penrite green keeper oil) for over 5 years. No pump issues, runs fantastic, cold starting with in 1 crank, no injector issues. Never had a problem. Mate has an 80 series 1HZ was sceptical and has seen me use it all this time, finally convinced him to use some, with in a week noticed better idle, economy, and starting etc.. What convinced me, l had an old (20 year)Victor lawnmower (as we all did), decided it probably need new rings etc. Once l opened it up, no sludge or carbon build up, so basically after 20 years clean as a whistle!!! And lets face it we were not always kind to our mowers. So the 2 stroke oil keeps things lubricated and clean.
there would be plenty of diesel engines around with excess of a million kilometers and seen nothing but good clean diesel, your 1hz is barely run in
blaze
I did it way back . Its $1200 or so for a rebuilt pump . Over the years $40 to $60 a tin of two stroke would soon pay for that ! I used it as temp measure to uncarbon the engine . It softens the carbon in chambers, ( not adding to it !)  the water injection did the rest . Can tell by how clean the glow plugs are . Starts much easier . Plus these engines suffer stuck or sticking valves . More often use has made a big difference. Short trips with diesels is bad news !!
-- Edited by Aus-Kiwi on Sunday 11th of August 2019 01:06:47 PM
After having to pay for a complete pump rebuild on the Hino with only 135.000km on the clock at the time, I'll be adding the 2 stroke oil with each tankful. Clouds of black smoke gradually getting worse and worse was bad enough, but the failure in the governor restricting us to 70km/h at best all the way back from Perth was the last straw. When the pump mob pulled it apart it was very warn and we were told it was common on early model pumps with the change to low sulphur diesel. Who knows, but the cost of the pump rebuild would have bought a lot of 2 stroke oil.
T1 Terry
Hi there. In my opinion diesel is already oily enough so adding more would not be a good idea. I have a diesel Patrol & have fitted water/methanol injection to improve burning ( oxygen in water ) & reduce exhaust gas temperatures.
" Don't stress more than management "
