Post Info TOPIC: Dual battery charging via a C.Tech charger
I have a dual battery system.
I have only used the C. Tech charger on a single battery.
Do I have to plug into and charge each individual battery, or can I just connect to one battery and the unit will then charge both batteries???
Jay&Dee
What are you trying to achieve ?
How are the batteries connected to each other?
Just to clarify your battery system, do you mean you have 2 batteries in your cvan or do you mean you have 2 batteries in your tow vehicle, one for engine starting and a deep cycle one for a fridge etc.
Jay&Dee
 I have 2 batteries in parallel in my van, normally charged by solar panels and car when traveling.
When home I charge each one separately to ensure both get fully charged. I have a fuse in the circuit to disconnect one battery from the other. Best to charge separately if you can when using a stand alone 240v
charger.
Reason to do it this way is because one battery may have more charge than the other ,or be older or just have different characteristics,  the charger sees the voltage of this battery only and cuts back the charge rate on both. So one may never get fully charged.
Cheers. Chris.
Chris & Sharyn.
Tea Gardens. NSW.
 Apologies for not being a little more explicit in my opening remarks.
The 2 batteries in Question are connected together in the special front boot of the Coromal Princeston Van.
Both batteries were installed and connected brand new about 3 years AGO.
Sooooo.....I am getting the view that I should disconnect all wires / cables from  both batteries and C.Tech charge each individually.
Current reading on the charger indication panel at 7.0pm last night was 12.8 Volts.
The charge goes up  to 13.3 when the solar is in action during the day.
I was thinking of giving the batteries a charge boost before we leave on a 3 month trip to S.Aust later this month.
Any clues would be appreciated.
Jay&Dee
P.S.  The Cruiser has a dual battery system.
No need to disconnect them, just connect the charger to a +ve and a -ve from either battery that is convenient and let it do its job.
To check each battery before your trip, charge them both together (dont disconnect) with your charger until it indicates fully charged. Disconnect the positive wires from both batteries and leave them sit for about 12 hours.
Check and compare the voltage of each battery with a voltmeter (one that reads to 2 decimal places). The voltages should be about the same. If they differ by say 0.2 of a Volt or more, charge the lower voltage battery again, let it settle o/night and do another voltage reading. If this reading is higher than the first reading it indicates the batteries are not getting fully charged when charged in the parallel connected state.
What AmpereHour rating are your batteries?
Chris & Sharyn.
Tea Gardens. NSW.
 should never ever disconnect the positive lead first on a neg earthed battery, can make lots of sparks and explode a battery
blaze
blaze
 Caravan battery Negatives should not be Earthed Blaze. Good point though.......
Frame will  still be earthed from the Car Battery though (for van tail lights,blinkers etc)  so yes it is still possible when the van is plugged into the car to get sparking between the van battery Positive and earth....
So when disconnecting the Positives wrap them up in electrical tape.
Chris & Sharyn.
Tea Gardens. NSW.
If battery nehative terminal agm in van doesnt go to frame (earth) where would it go?
 any van or camper I have owned has an earth to the chassis somewhere, although you could build a system with all earths returning to the neg terminal through some sort of buzz bar. not my cuppa though
blaze
 Circuit negatives should go to the negative tabs on the power supply or at least a negative terminal post directly connected to the battery negative.
Battery negative connects to the main neg' terminal on the power supply or to a separate post (as above).
-- Edited by The Travelling Dillberries on Sunday 4th of August 2019 07:05:20 AM
Chris & Sharyn.
Tea Gardens. NSW.
hi
Technically better to go to chassis but more reliable to have a wired earth .
By comparison
A car has can chassis earth in specified areas for low priority circuits .mostly easy to get to .
Some van chassis earths I can imagine are very difficult to access.
Wired earths always preffered.
In my motorhome., it has a bolt through steel section . Part of battery box . It has all the earths attached. Then cable to - on battery . Ive always charged as said + on one battery - on the other side . On 12v system
Batteries in parallel. Series with >correct< voltage setting !!
