Post Info TOPIC: 3 way fridge
3 way fridge
Any feedback on the best 90/100ltr 3 way fridge?? I note Dometic have a new model out, but cautious on new models. TIA for all and any help. Bas
Why the query Baz +Eve?
Are you building or renovating a van?
We had one problem with the Dometic 90L fridge in our Eagle camper - on inverting it to remove "for repair", I fixed it. It was the common RM2360.
Whatever unit you look at getting, if you are heading for the Tropics, consider adding a shade cloth shade over the exterior vents (a piece of shade cloth, a piece of sail track fixed above the top vent, two bits of rope (top & bottom), a piece of 5mm dowel to hold the cloth in the track & two tent pegs does the job. ALSO fit a 12v computer fan at the top & bottom vents - the bottom one to blow upwards, the top one to suck the heat out.
I'd suggest you ask the local service agent(s) for issues.
It is for my Son. His little 3 way Electrolux packed it in. I said to him the grey nomads will know. Thank you for your post.
Hi again Bas + Eve,
A few decades ago I had a 25-30L Finch fridge. Had the 240v element pack it in once, inverted it a few times to recirculate the ammonia solution, then had it repaired by a company at Dry Creek (Adelaide) - it was better than brand new.
I assume your son had chosen a 3way so that he can run it on gas in remote areas. A 12v fridge (with battery & charging system eg solar) is far more efficient but can be expensive.
Have a larger 180 litre 3 way Thetford fridge which is excellent. Used it all over Oz in all temperature conditions and it has performed faultlessly on all 3 power sources. Very happy with it.
Greg O'Brien
