Post Info TOPIC: wireless reversing cameras
Hi all can any recommend a good wireless reversing camera ? currently have a camera on rear of motorhome but it doesn't have the coloured guide lines on screen that would be a big help when using .
Been looking at the kogan for $69
Have chosen wireless as its an easy diy job just connected to reversing lights .
Anyone have any thoughts on this ?
Dunno about them but l added the wireless garmin camera to my garmin gps and l love it. Pricey but worth it.
Home is where I park the rig.
Tug 2016 D-Maxine
Den 2009 Goldie RV
G'day goldenyears,
Possum3 posted a warning about Kogan on the 23rd of May in the General Forum.
I was advised not to go wireless as they are prone to interference - so I bought a wired type. Guess what? The ultra thin cable is a metre too short! So it is still in my garage - unused! Luckily, it was cheap.
Thanks warren ..  yes I heard about the interference issues sometimes .. but also good reports ... will probably try one of the cheap ones ....
I have have a 2.4Ghz wireless camera mounted on the back of my caravan, so I can watch for following traffic. The 7 inch monitor clips over the rear view mirror. Apparently it operates similar to RC Model Aircraft radios with 'rolling' frequency hopping to counter any interference. The camera has operated flawlessly over the past 2 and 1/2 years and 13,000km of travel. It was not exactly cheap. There is an agent in WA (Perth?) that sells this equipment. As an aside, with my unit the coloured 'backing line' bars can be turned on or off - a Menu item. I have them turned off as I don't use the camera for reversing the caravan - my wife does guide duties in that situation.
what was the brand bald ed ?       thanks
Goldenyears, why don't you try to update your old one with a newer wired one that has all the requirements that you need.
The wiring is all in place, just change the camera and monitor, worth a thought........cheers Bob
Make it Snappy......Bob
Goldenyears. No name brand. I have sent a PM.
hi bob ... current camera up on roof is wired and just a rear vision camera that is on all the time .
need a camera that's lower near rego plate ..
good suggestion though thanks.
