SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest VisitLockhart
Post Info TOPIC: 100 series engine warning light
hi, just want to know if any one has the same problem. warning light comes on and car goes into limp mode, pull over and turn off for a minute
and turn back on ,light off,drives normally.had auto sparkie look at it and said it was "throttle position sensor cable" fault. cleared it but now it
has returned. took it to toyota and they said they could find nothing wrong.have heard that someone had same problem and they had fixed it
buy replacing a cable but i could not get any more info.hoping someone can help with pictures or diagrames       thanks       terry
Hi Terry ,sorry cant help with your problem other then suggest you join the landcruiser site LCOOL its called and ask their .
Not saying this will work, but worth a try. A mechanic relative once told me that with a lot of these type of problems, if you disconnect the battery for 10 minutes or so, then reconnect it, it will reset the cars computer and the problem will be rectified.
HI
Many codes relate to a circuit eg wiring loom and end unit say TPS sensor . So either can cause fault but intermitant is likely to be the wiring loom in that fault circuit .
Hi Terry. Mine is doing the exact same had it checked out at Toyota and they say it needs the throttle control motor changed out at $912 , well sit on it for a while , talked to a mate and he had same problem and he change the wiring plug at the throttle body ,
You could give that a go .
S G Eatts
Hi had this same problem with our 100 series just prior to selling it to our son . After Toyota telling us to replace the main computer box our mechanic found that a wiring harness was shorting our on the chassis. Repaired and problem solved $1000 later . Still cheaper than the first option.
hi, thanks all i will look at all suggestions and try to solve problem when it happens again       terry
