Post Info TOPIC: Slow draining sinks.
Technical or General, I think general? but our sinks were very slow draining, usual comments blocked breather in the grey water tank, valves all gunked up etc etc. I set to and got rid of any bends in the pipe work that held water, i.e. made a valve like an "S" trap and whalla, the water drains with a vortex and a gurgle, all fixed.
This has plagued us with the kitchen sink since the van was new - shower and vanity aren't a problem. I did similar and removed some bends in the sink drain but it hasn't changed anything. I find it helps a lot if we swirl the water quickly in one direction to create a whirlpool effect, then seems to drain much faster.
 The moral: Focus on the Facts
I increased the size of the pipe going DOWN under sink . I dont think the smaller sink
Plug outlet helps ? Was going to fit an inline (black water) pump ? The extra size down pipe has helped adding extra pressure to pipes outlet .
Last year a lady asked me why her sink was so slow in draining.
A cursory look at the pipework just looked as  standard for an Avan Cruiseliner.  Then I saw her sullage hose connected to a 12 mm snap on Hose connector and also a short piece of 12 mm hose fitted to the sink outlet under the van. Then the 25 mm sullage pipe. Numerous 12mm snap connections fittings and reducers etc.   ???????
Mike & Ellie
 Yep, fittings like that would certainly slow it down. It's not the case with ours though.
