Post Info TOPIC: STONE PADDING ON FRONT OF CARAVAN
We have a Coromal caravan and the rubber padding on the front of the van has been damaged by stone chips.  We wish to replace it and wondering where this product is available. I have tried the internet with no success. We are not interested in replacing it with aluminium checker plate.   Thanks in advance
5005 alloy plain sheet aluminium or 5251 marine grade flat sheet.
Check out local Motor Trimmers they should be able to redo like original, or even make a detachable "Bra" for front of van.
Thanks for the info we will get in touch with them
thanks for the info but only interested in the rubber type material
robjoe,
When I had an accident (I backed into the van) with our Eagle, the repair man did it with vinyl with a thin foam sheet underneath. Was impossible to tell the difference between mine & a newer van.
Advice - buy or make yourself a stone guard of some type. Mine cost <$20. Is an el Cheapo Rock Tamer.
Try Clark Rubber, they might not have the exact same thing but may have something similar or just as good. I used a black checkered rubber matting for the same purpose from them on my old Millard van a few years ago.
thanks for the idea - will look into it
Gday Warren
I'm thinking of making a stone guard/rock tamer.  Photo of your design might be helpful.
Thanks
Glen
-- Edited by Treecrest on Monday 1st of April 2019 12:41:00 PM
-- Edited by Treecrest on Monday 1st of April 2019 12:41:39 PM
Treecrest wrote:
Gday Warren
Thanks
Glen
Look at thus concept,,, much better than what you pay $500 for IMHO.
Cost about $100 depending on how thick yr rubber is. Mine is 10mm so heavy enough to stay in place.
Re Clarke Rubber
I purchased some silver Checker Plate rubber or vinyl matting and installed on son's Caravan prior to sale and it looked great.
Maybe similar to stuff below, but it does not appear to be checker plate.
....www.clarkrubber.com.au/supafloor-studded-flooring#
Thanks Peter - it looks strong to have a car drive on it
Robjoe, Yes Clark Rubber sell it in a silver and also Bunnings sell it in black about $30 a lm.
Good time to invest in a Stone Stomer protects van and tug.
-- Edited by Moonraker on Tuesday 2nd of April 2019 09:21:20 PM
The black sounds good - will have to call into a Bunnings store - thanks
