Post Info TOPIC: Primus brake controller for caravan.
Good evening all, my first post and I'm really happy to have found this site. I have a Primus caravan/trailer brake controller which is showing the letters S.T on its display when the van (which has a 7 pin round plug), is hooked on. Clearly this is a wiring issue but I wondered if anyone either a) can recall this subject being previously discussed or b) perhaps can offer a solution (I am absolutely useless at anything electrical!!). Many thanks in advance.
I had my primus codes.jpgowners manual stolen the other day, so I can't check for more codes other than what i found on net...
EJP
Can't help you with the ST display. The chart shown above is for a Tekonsha Prodigy brake controller and may not be much help. If you are not electrically minded then I suggest you see an auto electrician and get the problem fixed properly, and safely.
EJP
Thank you for the replies. I didn't have a manual in the first place so that is appreciated. But, auto electrician here I come I think!
The Primus is much the same as the Prodigy, just missing a few features. Get its Install sheet from here.
The indication indicates Power interruption while brake pedal is depressed.
