SmartBar SmartBar
Post Info TOPIC: jockey wheel clamp handle
wondering if you can buy the jockey wheel clamp handle  with the thread
not the al-ko  one  with red handle  because its bigger and does not fit
thanks
A good machine shop would be able to make one if you have original to discern thread.
The thread in the nut section could be possibly getting stripped as well.
Aussie Paul. smile
 What does not fit? The handle or the thread? If it's the handle you could chop a bit off.
You should be able to get a piece of threaded rod with the correct size thread. M10/M12 ?  Use two nuts to lock at the correct length Maybe a washer as well. Then and bend it in a vice to the angle you want, then  cut to a length that suits then use some Duct tape to wind around the rest to make a handle.
 thumbsup.gif thumbsup.gif A man after my own heart.biggrin
Aussie Paul. smile
-- Edited by aussie_paul on Monday 14th of January 2019 02:55:55 PM
 Exactly what I did with mine about 5 years ago.  Still going well.
I would buy a new bracket off ebay
blaze
