Post Info TOPIC: Potential to cause caraavan fire
Hi Caravaners,
just thought I would share this
I had to take our oven out off the caravan to change out a thermocouple that wasn't working
when the oven was removed I found the plastic edging had been burnt due to the heat off one off
the gas rings
looks to me like a design fault by Coromal  to have fitted the oven up against the plastic moulding
I have removed the plastic moulding and replaced it with exhaust heat wrap
Problem fixed
Not good.
Will spend a few minutes checking around our stove top and oven to make sure all is good.
Thank you.
-- Edited by Radar on Friday 11th of January 2019 06:15:05 PM
Thanks Ken, will check mine as everyone should. yawn
Chris & Sharyn.
Tea Gardens. NSW.
This can happen when someone puts a pan larger than gas ring on the stove - they are only meant to use certain size pots and pans. This is basically the same result that caused the compact Chinese butane stoves to be withdrawn.
