Post Info TOPIC: AIR CONDITIONING COMPRESSOR NOT WORKING IN COOL MODE
Ibis 3 unit compressor works in heating mode but not in cooling mode.
Filters are clean.
Kevin Kyle
On the road full time with Son and 21 year old cat and 3 year old Manx.
Toyota Landcruiser 100 series V8.  Nextgen semi off-roader.  3 120 AH agm batteries, 1KW Solar
Sounds like it needs a re-gas. Elsewise thermostat not working. Technician required either way.
Thanks Possum, thought as much.
We are in Armidale atm so not holding out much hope getting it done here.
Kevin Kyle
If it works in the heating mode I would look for other things rather than a regas, eg faulty switches, connections etc, but agree a Tech is needed
Some aircon with heating have the heating done with an element not the gas and compressor.smile
Aussie Paul. smile
Thank you all.
tried Auto mode, temp set to 22 deg, ran heat until about 10am then switched to cooling and is working.
Strange logic at work here! See how it goes tonight.
Kevin Kyle
