SmartBar
Post Info TOPIC: Battery Corrosion while away
Have arrived home and found items with batteries, ie; clocks, remotes, pleasure aids biggrin etc not working and upon checking the batteries in the devices I noticed a couple of them had started to leak and cause corrosion.
I will be removing the batteries in these devices before we travel again
Apology if this has been mentioned previously.
-- Edited by Dickodownunder on Thursday 8th of November 2018 01:39:40 PM
Travel Safely
The *only* dry cells I have found which do not leak are Duracell.
Mike, our batteries were not Duracell so maybe you are onto something there.
The cost of the Duracell is generally not much more than the others. For now I have fitted new no name brand batteries and I will remove them when we leave home again.
Travel Safely
always.remove.safe.buying.all.new.gear.tip.from.ex.mech.boiling.water.removes.corrsion.from.main.vehicle.batt.leads.
Funny. I have had the same problem but always with Duracell. Will not buy them now.
Greg O'Brien
