Post Info TOPIC: Cracked Windscreen
Cracked Windscreen
Hi, I recently had a stone crack/chip my windscreen. I was in Ballina NSW, and contacted Wisecracks, and they were absolutely amazing, and filled the crack the next day for $65. Windscreens O'Brien were double this. Fabulous friendly efficient service. My tip would be as soon as it happens to you, try and keep it clean. Wisecracks don't do complete windscreen replacements, but will give a good recommendation for a local company...
Avan Ovation M7 with Fiat Ducato 3 Lire diesel engine, 2 x 160watt rooftop solar panels, 3 x 100a/h batteries, self contained with separate toilet [SOG NO CHEMICALS], and shower, 100 litre fresh water tank and 100 litre grey water tank
Or buy a DIY kit to keep in the glovebox and do it straight away for about $10.
www.google.com.au/search
Hi Splottboy,   I used on of these 5 years ago or similar, and it hasn't been a problem. I had never used one before but seen it done.
https://www.supercheapauto.com.au/p/ufixit-ufixit-windscreen-repair-kit/209369.html
The secret is to get the glue down into the plastic layer they say. And also do it asap.I know it was cheaper those years ago, but today going for as little as $15-00 on ebay.
I doubt that Supercheaps quality would be much different to the other cheapies.
I know folks shy away from these jobs, but I know that wind screen mobs have a high turn over of bodies, and it is just a street man with 5 min of training doing the job.
Retired plumber & Plumberess
 2004 Toyota TD LC
A'van Tayla 17'6" Caravan
Thanks... The big problem with replies on this forum is that the great and quick forum is that not enough questions are asked. For example before replying to this I think the first question should have been "how bad or big is the chip", as in this case it had come right through the windscreen which might have generated a different response. The job that Wisecracks did was fantastic and I am very happy.
Mines covered with the insurance and I do have the little stick on ones for smaller chips if req.
Dick.
If you have insurance put super glue on the chip or crack will stop it from running, will get you home no trouble,can last up to twelve months.
Thanks everyone ..
Topic now closed so thanks everyone ...
