Post Info TOPIC: Flair Manual Press Espresso Coffee Maker.
If you are an espresso drinker you will be impressed with this device from Flair Espresso.
No power needed and produces shots comparable the the best machines available.
Comes with a carry case.
Great little travel setup.
You will need a good hand grinder to to get the best from it.
https://www.coffeeparts.com.au/flair-manual-press-eco-espresso-coffee-maker-bundle-set-with-2-brewing-heads
Image result for flair espresso
-- Edited by Santa on Wednesday 24th of October 2018 08:36:34 PM
-- Edited by Santa on Wednesday 24th of October 2018 08:38:26 PM
Santa.
Looks quaility but I'll stick with the minipresso in the van , being able to buy ready to go capsules makes it simpler and less cumbersome . I love our caffitaly machine from coles at $69 for at home , lot cheaper than the $270 for that bit of kit.
As I said in the OP, if your an Espresso drinker, if your happy with pod coffee investigate no further.
$279 is only for the Flair, allow another $100 or so for a decent grinder.
Santa.
The Aeropress is a lot smaller, simpler, and cheaper, gets pretty damn good reviews as well. That and a hand grinder and away you go :)
https://www.productreview.com.au/p/aerobie-aeropress-coffee-and-espresso-maker.html.
Time for fun
The Aeropress does not make espresso, if your happy with French press type coffee investigate no further.
Santa.
