SmartBar SmartBar
Post Info TOPIC: Satellite finder
Satellite finder
Hello fellow members, i recently brought a satlink ws6906 finder, thinking that it would make life easier, but i can't get the thing to find any satellites, i am only after the Optus c1.can someone please help,i would appreciate it,thanks.
Hi Subaru,
I cant directly help with your enquiry but here is a topic from a few years ago on that finder.
I do note that at times they need a software update.
Here is the topic
thegreynomads.activeboard.com/t57225200/satlink-ws-6906
Travel Safely
Keep in mind that your satellite finder is only as good as its antenna and at satellite frequencies the antenna cables and connectors must be pretty much perfect.
The Optus C1 and D3 birds seem to be at 156d:
https://www.lyngsat.com/asia.html
Manual:
http://www.nikingstore.com/support/WS6906.pdf
And have a look here:
http://www.satsig.net/cgi-bin/yabb/YaBB.pl?num=1422788070
thanks all, i ended up going to a sat shop,where,for $20 the guy reprogrammed it and all is well(at the moment)Cheers and thanks for your imput.
