Post Info TOPIC: Filling 70lt tank with elec pump
Hi guys hope all well.  A question i have a 70lt water tank on top of tradie trailer. It has a  A 2.6 ft poly pipe and **** and hose fitting for my out let to fill by hose and to fill kettle etc, tthe pipe comes down the back of trailer ( tent camping) (above this i have the solar panal on the ladder rack) now i would like to use a 12v pump to fill when i dont have hose available.  Fill out of bucket container etc.
This would be a lot easer than trying to conecting to top filler point a bit hard to get to.
Its not a very high tank same as ones under caravans it has a small breather hole.
So back to question a pump that will pump up that tube and fill tank from bottom and if so any idea on size of pump. Please lo arguments and yes i take my garbage home jk lol
Thx Rob
Rob convery
Hi rob , we just use a small 12v pump ( cheapie ) , pumps about 5 litres per minute ....does a great job for its size , think it was about $25 when we bought our water bladder .... think they're on the bay for around the same price
l added 5m of leftover 6mm and an Anderson plug to it
-- Edited by kesa32 on Sunday 30th of September 2018 09:19:33 AM
I use a similar 12v pump with an anderson plug with switch, onto my solar controller (3rd connection on right). That is how I fill our tanks when free camping! Works very well.
KFT
I bought a 12v submersible bilge pump from BCF and added fittings so I could use it to fill my tanks. I just drop it in a bucket under a tap and plug it into the anderson plug.
Avagreatday.
I bought a small submersible 12v pump from AliExpress (google "DC 12V 5M Pumping Head Mini Submersible Motor Brush Water Pump for Garden Fountain Aquarium"). I use this to top up my caravan tank from the 20 litre container in my tug. Pumps at 10 litres/minute.
Thanks guys do you think these pumps will fill from the bottom of tank against the weight of water thoe its not very high ?
Rob convery
 Look up the technical spec. for the pumps to see what "Head" they can pump to but I think they'll be OK. I use a $25 BCF bilge pump (no longer sold by BCF) for my shower which is about 7' off the ground and it provides more than enough pressure/flow for that.
The small pump I have has no problem pumping from a container on the ground. The tech specs state the pump is capable of providing a 5 metre head - far higher than I require. I power mine off the 12v cigarette socket in the back of my tug - I did have to extend the power lead a couple of metres before wiring up the plug.
Hi balded is your a submersable ? Yes for what i want im prob over thinking it just sick of getting it wrong all the time and forking out cash i have enough little things i need and they all add up like i need a tv arial i know i need a decent one bu not overboard with cash im on a disability pension you look at all the caravans and there are such a wide range and if you ask everu opinion is oposite even the same arial.
I have been at Merbine common over 3 months have gad so many teething troubles just changed the petrol pump today so im here for another 3 weeks lol im growing roots
Again thx guys
Rob convery
RobC:
In my first post you will see that the pump I referred to is submersible. I bought it online from China, I forget exactly which shop, but it was probably one of the Ali Express shops that offered free shipping to NZ. The cost was <$10 US. It took about 3 weeks to arrive. The pump is thin enough to fit down through opening in the top of one of those square 20 litre water containers that most plastic shops sell. A minor problem is that pump tends to want to float on its side. Easily fixed - I just zip tied a 50cm stick to the pump body to keep the pump vertical in the water container and thus the pump inlet on the bottom of the container.
Thank you will start browsing now i have your info
Rob convery
