Post Info TOPIC: Replacing old push puttons from cupboard catches .
Replaced catches in motorhome. Hope this helps others . Here I used 3/8 drive 3/4 socket to hit out on push in surround . After takeing two screws out to remove catch . The pushed new surround in door or drawer . Screws button on catch . Assemble . Done . Good for another ten or so years ..6E6C7DA2-FF2C-43D0-BF6C-58B4BA956A2A.jpeg
A little out of sequence . But hope it can be worked out . The socket helped big time . I used a screw driver on first one . It can damage the door . HTH Graeme
Don't replace these when they stop woking. Use a bit of a cable tie as the spring replacement, it will outlast a new one. Once you open up the back, you can see where it needs to be very easily.
Neil
 AK, where did you get the replacements from & how much each???  I've got a few that need replacing.
Never mind, found them on CaravansPlus.com.au for less than $5 each plus postage.
Camec 16mm Nickel Catch Set - Catch / Rosette / Knob / Strike Plate
From a place in Silverwater nsw . There was nothing wrong working wise with old fasteners . The GOLD had warn off . She who is very house proud wanted them replaced . Gold is not available anymore .So silver it is . Kinda looks better from the wood colour anyway . These are approx 22mm.  Be aware most are 18mm .
-- Edited by Aus-Kiwi on Friday 18th of January 2019 07:54:07 PM
