Post Info TOPIC: Aux battery
Aux battery
hi everyone
i am buying a small fridge and connecting an auxiliary battery and solar blanket.  Can anyone tell me what type of battery to purchase.  I drive a Suzuki Vitara.
 Thanks in anticipation
Jacaranda
J M Hannon
Tell us more about the fridge.
NB. This may not be a simple process :)
It is a small Kings fridge Mike cost about $600
J M Hannon
I would suggest - One of these - They are rather large, none under 60L.
Is that a fridge for diminutive monarchs? :)
I think Peter is right:
https://www.4wdsupacentre.com.au/adventure-kings-fridge-60l-fridge-freezer-7276.html
You appreciate this fridge/freezer can *only* operate as a fridge or
freezer, despite having two compartments?
So I'll assume you'll operate it as a fridge. I also have a 60lt
fridge freezer which can operate as both simultaneously:
https://techniice.com/ss-fridge-60l-dual-6hdr.html
I run the freezer at -12C and the fridge at +2C. Power consumption
varies with the ambient temperature, as you would expect, from 25Ah
to 50Ah per day in temperatures from 15C to 35C. I'll guess that if I
ran the whole unit as a fridge it would consume from 15Ah to 30Ah
yours will probably use a little more.
Battery size:
You have to operate to worst case so you really don't want to be
discharging the battery to 50% on every hot day so I suggest you go
for an AGM battery with a capacity of 80Ah, or better, 100Ah.
https://www.ebay.com.au/itm/100-AMP-HOUR-BATTERY-AGM-SLA-12-VOLT-12V-DEEP-CYCLE-DUAL-FRIDGE-SOLAR-100AH-/400634846758?hash=item5d47b29e26
Then you have to charge it!
We'll do charging stuff later after you tell us whether you have
solar, a generator or plan to charge whilst driving.
btw; this post should really be in the "Technical" section - more
people will see it there.
You are right this is complicated - 30 kg fridge/freezer I could not handle I am afraid.
J M Hannon
Maybe my current method of ice in an esky will suffice.
J M Hannon
Not for long, I suspect.
Ask again if you seek further information.
 With that setup in place already, how about an 18 litre Engel run as a freezer?   Mate has similar setup in a Jimny.   Make your own ice overnight and run as fridge through the day.   One two litre bottle of ice per day keeps milk and butter cold.   Vegies only need cool.
But to the original Q, not less than 50 AH of usable capacity, so something like a 100 AH AGM or a 50 AH LiFePo4 and 120 - 150  Watt Solar panel.  Both the LiFePo4 and the small Engel are space and weight saver sized items.   AGM is easier to set up for charging.
Iza
Iza
Thanks All
Gives me time to think of my options
J M Hannon
