check out the new remote control Jockey Wheel SmartBar Topargee products Red Earth Festival Park Booker Mackay Festival of Arts
Post Info TOPIC: Leaking Thetford Cassette
Our cassette leaks when held vertical on the way to emptying. The leak comes from a yellow switch a little over half way along the top.
Actually, while it works like a switch it appears to be a two position change over - some sort of valve perhaps as there is a 'clunk' when turned about 30-degrees?
I have been unable to find out exactly what it does, so at this point cannot know what to ask for in parts - if available - to fix the leak.
Does anyone know what that change over switch is used for?
The switch has been left in the one position since we bought the van and it has worked OK installed.
Regards,
Murray
It opens and shuts the round cover to allow your waste to go in canister. Remove big round section on top of canister and give a good clean. There are some moving parts under that and could do with a little lubricant from time to time.
Do a search for Thetford Canister here on the forum as I put up info and pics this time last year. You might need to use a diffegent word as I can't remember what heading was.
It's in 'hints tips and great ideas' Murray.
Praps this will help you to understand how it works ....
Thanks Chief Dougwe,
I'll check it out tomorrow.
The cassette is one of the older ones without wheels, meaning that it has to be carried by the top handle. When I put my hand on the bottom handle to upend it - yuck!
I bought a new one with wheels and if I can fix up the leak on the old cassette that can be used as a spare.
Regards,
Murray
Hi John (rockylizard)
Thanks for the picture. No.1 is the switch that leaks. There will probably be an 'O' ring or something that can be replaced.
I have to say that the description of No.1 is a bit hard to follow. Perhaps it has been translated from German - or where ever Thetfords are made?
Actually, I first thought that the leak was from the two shell halves of the body, but after filling the cassette with water and standing it on end saw that the water was coming from the No.1 switch.
I'll have a look at fixing the leak in the next few days.
Thanks agai
Hi Long Weekend
The same happened to me about six months ago
Part number 1, in Rockylizard (John) picture started to leak, as I carried the cassette
I purchased that part, (blade opener) and also replaced the (lip seal), and fitted them
From memory I brought the parts from Caravan Plus
Watch the video below a few times to see how it is done, because everything will be by feel, as you can not see anything
This is for my cassette, older one without wheels C200
https://www.youtube.com/watch?v=Ry5TmMX3CNk
Hope that this info is useful to you
Hi Tony (Bev)
Many thanks for the link. I watched the video and feel that I should have no trouble in doing the maintenance. Looking at the cassette it appeared to be a sealed unit and therefore not repairable.
I'll make sure that my gloves are a bit longer than the ones the person in the video was wearing though!
As it happens I regularly buy items from Caravans Plus so am familiar with that company. For anybody that has never bought from them I can recommend them.
Regards,
Murray
Mate what a crap problem! I've got a green one so carnt help!
Home is where I park the rig.
Tug 2016 D-Maxine
Den 2009 Goldie RV
With any cassette toilet the rubber O-rings/seals need cleaning & lubricating regularly, we use olive oil spray.
Cheers Keith & Judy
Andrew mate, "green" crap. I'd see a doctor about that cos it can't be easy being green.
Still on topic Murray, well sort off anyway.
Hi Keith and Judy (one being the Desert Dweller?)
Thanks for the information. As it happens I keep a aerosol can of olive oil in the en suite to give the bowl a squirt from time to time. I'll be replacing the seal and the blade opener assembly in the near future and will make sure they are lubricated.
I bought a brand new wheeled cassette to use in the meantime, after repairing the old one I'll keep it as a backup.
Thank you to all who responded.
Murray
-- Edited by Long Weekend on Wednesday 2nd of May 2018 03:58:43 PM
Identifying Your Thetford Cassette Toilet Model - That link goes on and leads to spare parts listings.
-- Edited by PeterD on Thursday 3rd of May 2018 08:43:42 AM
Thanks for that Peter D. But I had already printed out a listing of parts and prices from Caravans Plus. As there is no rush because I now have the wheeled cassette I'll buy the parts when we return from our rally next week.
By the way, the prices of parts from Caravans Plus beat anywhere else - including eBay.
We have only just bought our first caravan with an en suite - so the 'care and feeding' of the cassette was new to us. Previously we had a Swan Camper Trailer and Jayco Freedom but the wife decided that she wanted an 'inside outhouse' to avoid night time trips in the dark.
Murray
-- Edited by Long Weekend on Thursday 3rd of May 2018 09:46:43 AM
 You have a leak in your link, Peter
It comes back to this page
Tks, fixed.
