Post Info TOPIC: Diesel fuel
Diesel fuel
A fellow traveller told me that a diesel heater can be run on kerosene.
I have never heard of this but has anyone any knowledge about this?
Chris  no
Every one dies but not everyone lives!!!
If I can't get Winter diesel for the caravan heater I add 10% Kero to stop it waxing up.
 Ditto, but kero costs lots more than diesel, so no point adding more.
What is Winter Diesel? Do we have it in Australia
Probably not a good idea. The reason I say that is when servicing diesel injectors the mechanics only use kero because it does not vapourise into a highly inflammable mist. If it is not as inflammable it won't produce the heat.
I wouldn't use kero anyhow.
Neil
 Winter diesel waxes at a lower temperature than summer diesel. On the farm the fuel company delivered use summer fuel at the start of winter. Would not run out of the over head tank until the afternoon, providing the weather did warm up. Solution, add a bit of kero, but nowhere near 10%. Probably 1/2 gallon to 500 gallon did the trick.
Neil
Sorry Woolman - I cannot resist.
The word 'inflammable' hasn't been used for many years because it actually means it doesn't burn.
The word is 'flammable' which you see everywhere there is something that could catch fire.
Check out the back of a tanker next time you see one on the road.
Murray
Kero is more flammable then diesel that's why it is used only sparingly during winter months in the diesel heaters, you can't run them on kero alone without destroying them.
Kebbin
Hi smile
While I am no expert on this subject that will not stop me from expressing an opinion. biggrin
Diesel and kero are very close to the same basic specs. However it does depend on the original crude oil they were distilled from. Crudes are not all the same or even similar.
Kero is distilled as a simple fuel with no additives needed to burn it, while diesel is distilled with specific burning characteristics for engines and has additives also to help things. Jet engines run on basically very clean kero. A bit of kero added in small quantities would be OK IMHO. Never had to use winter diesel.
Neil
BP recommends this
Hi Plain Truth smile
That was interesting thanks. I googled a bit on that info and here is a reference to the complete BP statement for those more interested in the subject !
The Australian standard has Australia divided into 6 zones for the supply of suitable blended diesel for the temperature expected there at various times of the year. So there is more than just "winter fuel" hmm
 https://www.bp.com/content/dam/bp-country/en_au/media/fuel-news/winter-diesel-problems.pdf
-- Edited by Jaahn on Wednesday 25th of April 2018 07:02:23 PM
is heating oil a mix of kero an diesel
No it is just cheap less refined diesel distilled for,....... you guessed it ....... heating biggrin
Diesel is considered "combustable"
Petrol & kero are "flammable"
The terms used are dictated by ignition temperature.
Sta
The term "inflammable" has nothing to do with burning. It comes from the word inflame. Inflammable liquids, or situations should never be considered safe. And I'm sure you'll agree that if you spill your "flammable " petrol around, you'll have a very "Inflammable" situation.
Hi smile
From Wikipedia !
FuelFlash pointAutoignition temperature
Gasoline (petrol)-43 °C (-45 °F)280 °C (536 °F)
Diesel (2-D)>52 °C (126 °F)256 °C (493 °F)
Jet fuel (A/A-1)>38 °C (100 °F)210 °C (410 °F)
Kerosene>38-72 °C (100-162 °F)220 °C (428 °F)
-- Edited by Jaahn on Thursday 26th of April 2018 09:38:44 AM
Chris  no
 A diesel heater cannot run on kerosene, because if it could, it would be called a kerosene heater, just as one that runs on petrol is called a petrol heater!, is there one that runs on petrol, according to Webasto there is, they have one listed.
The only difference would be jet settings and safety design. Gas turbine engines all run on kerosene, and some run on oil, or what ever is handy, be it called avtur or what ever, the main difference is how the fan is driven, the caravan heater has its fan driven by an electric motor, the gas turbine is driven by the exhaust of the engine, except at start up when the fan is driven by electricity, hence at that stage it is exactly the same.
So fundamently the answer to your question is yes, with adjustments, but don't try it!, it'll void your warranty and you may get burn't.
Thank you for all the replies.
It seems that the person who gave me the info was wrong.....and should get his facts straight.
Chris
I wouldn't say that, the heater that I looked at on the net (Webasto) is the same design, I would guess the jets would be different between fuels, but the design is still the same. 10% kero mix sounds OK, but I would contact the suppliers before using straight kero or petrol.
My guess would be different jets, and a different safety system for petrol, i.e. different computer program and safety switches.
Remember that these heaters would have been designed to go in machinery for example front-end loaders, trucks and the rest in cold climate countries, well before they thought of putting them in RV's. Probably designed during WW2.
I worked as a tanker driver for Shell for 17 years. Part of my job included taking winter diesel to cold climates such as Moss Vale, Crookwell, Cooma, Jindabyne etc. Depending on what use the winter diesel was for the diesel would be mixed either 20% heating oil or 40% heating oil to diesel. Shell used to automatically start mixing it at the terminal and deliver to service stations in cold areas and sell it as diesel. We used to take millions of litres to the snow fields every year.
I would not mix kero to use in a heater as already mentioned here it is flammable and in my opinion would not be safe.
Ashley
Diesel heaters don't actually have "jets". The pump dispenses pulsed doses onto a heated mesh.
-- Edited by Peter_n_Margaret on Thursday 26th of April 2018 06:21:34 PM
