Post Info TOPIC: Rear light housing
Rear light housing
Hi all. I hope the photo attachment can be opened.  The black plastic has cracked badly and needs to be replaced. For the life of me I cannot  find anything on the net and am not sure how to describe it.  The plastics housing hides all the wiring and runs across the rear of the van.  Is there anyone out there who can tell me the correct name  to describe this bar, and or where I may source the same.  Cheers. Daz.  From sunny Yorke peninsula
the seconds keep on ticking away
Put "caravan rear lights"into Google for hundreds of similar lights. Link below is for one type but size may not be right:
https://www.ebay.com.au/itm/2X-Rear-Trailer-Tail-Lights-36-LED-Boat-Truck-Ute-Caravan-Bus-Indicator-Lamp-12V-/232164724236?_trksid=p2385738.m4383.l4275.c10
Good Luck.
Thanks. Hako. But I do not need the lights. The mounting bar is what I require where the lights fit into or onto. Cheers
Would assist if we had the name of the manufacturer and model of the van.
Manufacturer on the move. Model infinity
On the move. Infinity
Ring the manufacturer:
1800 ON THE MOVE
If they don't know nobody does.
The black bar is just a piece of trim that is peculiar to that manufacturers van. You will have to source new ones through the factory or an agent. You will not get it from a spare parts place.
Go see someone that does plastic welding, they might be able to repair it.
Too many cracks to repair. Have emailed the caravan builder but no reply to date.
I'm presuming the black platic bar has many small cracks but no missing material. If you can remove the black plastic bar from the vehicle after removing the lamps you could turn the bar upside down on a table/flat surface, then thoroughly clean the surface and coat with some black silicone sealant especially around the cracks. This will not remove the cracks but it will stabilise the plastic surface. Additionally you could then spray the bar with flat black plastic paint which will flow and cover the cracks.
Not as good as a new bar but would cost a lot less.
Good Luck.
Ge
So how many caravan repair yards have you been to. Those yards are like wreckers accumulate a heap of stuff. My Son's repair business has a load of gear out back in containers, 40yrs worth.
KJB
Is it really necessary in the first place..........?
KB
