Post Info TOPIC: 6 wheels
6 wheels
Recently in Halls gap cp. For a couple of days I seen an unusual van, around 26ft. Long with tandem axles at rear like a semi-trailer, towing end was a pivoting A frame with single axle with ball coupling, no weight on tow vehicle with this set up but wonder how it would tow with 2 pivot points, hard to reverse I would think, anyone else seen this set up? Joda
J. Price
Did you get a pic?
Centrelink - Living the Dream.
Yep, got some shots on my camera, will try to transfer them to my tablet & put on to the forum (tricky stuff for an old fart!) Did not look home built, maybe converted from original van? Joda
J. Price
It is called a "dog" trailer. Conventional caravans are "pig" trailers.
"Dog" trailers tow extremely well, and are inherently stable, unlike "pig" trailers.
There is almost zero ball weight. They are very difficult to reverse, but a few people can do it.
I reckon that the "Gypsies" that used travel around NSW when it was legal used to have dog trailers whether they be pulled by horse or car.
Called a dog trailer because its always following you. anyhoo hers some pics.
J. Price
Would that van be classed an an articulated vehicle and hence require an endorsed licence of some sort?
Actually . They Are easier to reverse than a "normal rear hitch" set up . I believe . Old mate used to have a gypsy wagon with
two horses pulling it . And more stable than a rear hitch . I believe . I had an old farm trailer , I used to run around with.
I'd have one.
R & L.
Not R&L anymore , just.
R
Not sure about stability. I was travelling on a windy country road when a truck & dog trailer came towards us. The trailer was bouncing all over the road coming around a bend and nearly took us out.
The road trains travelling up thru the centre (Alice) also wander over the road a bit.
no way are they easier to reverse than a normal trailer there is an extra pivot point its the same as a second and third trailer on a road train i have done my share of steering them and it takes practice to reverse and dolly
did you actually see it under tow on a roadway?
It looks like its only set up to be moved about on site but not to travel. I could be wrong though.
No, was set up when We arrived, didnt get a chance to speak as they were out all day.
J. Price
Joda wrote:
Snip . .  towing end was a pivoting A frame with single axle with ball coupling,
 The front axle is similar to the front axle of vehicles pre-independent suspension. The tow pole is attached to the middle of the front axle, a tie rod between the pole and the front RH wheel steers the wheels..
I saw it being built in the Spaceland factory when I picked up the first of my Spaceland vans in 1997. The chassis was supplied by the owner and Spaceland built the body. As I remember way back then there is an office bench across the front, the rest of it was still being fitted out when I saw it.
I have since seen it parked a couple of times with a couple of different Land Rover Discoveries in front. The owner was not around each time so i did not get a chance to have a chat with him. It still looks in good nick.
