check out the new remote control Jockey Wheel SmartBar Topargee products Red Earth Festival Park Booker Mackay Festival of Arts
Post Info TOPIC: Wind turbine...
Wind turbine...
https://www.banggood.com/400W-Wind-Turbine-Generator-DC-12V-24V-35-Blade-Power-Supply-with-Charge-Controller-p-1176470.html?currency=USD&utm_source=facebook&utm_medium=cpc_elc&utm_content=dendi&utm_campaign=ele2-dpt-diy-rm-e4list-all&utm_ho=18&cur_warehouse=USA
Aussie Paul. smile
The rated wind speed is 13m/second. That is 47kph.
And you get ZIP at 7kph.
No mention of noise levels, so you can interpret what you will from that.
Therein is the problems for wind turbines for recreational use.
These have been talked about before. General consensus poor performance and was better to stay with solar.
Sta
Noise and vibration are the first complaint problems, next is poor performance due to not enough uninterrupted wind at a fast enough speed. Wind that has passed over any object or through a tree will have eddie currents that hinder a wind turbines operation, gusty wind is even worse. A vertical wind turbine does get around some of these problems but they require a much larger blade area to produce the same amount of power generation.
The plus side is some where that wind blows all night as well as all day, like close to the ocean, then power can be produced for 24 hrs rather than the hrs the sun shines so a good supplement to solar for anyone set up in such a position permanently ... but fairly useless for an RV traveller.
T1 Terry
I dunno. I recon you'd get plenty of wind as you drive along after mounting it on the front of the van biggrin
Live Long and Prosper
MN Triton auto diesel 4x4 & 20' 6" Kokoda Tribute II XL Platinum
:lol: The old perpetual motion machine. But being serious here, the drag required to drive the wind turbine must be added to the amount of  pulling power produced by the tow vehicle ... well except for the down hill bit wink Far more efficient to use the vehicle alternator and a DC to DC charger but even the alternator is only about 30% efficient if you consider belt drive losses as well as the losses within the alternator itself.
The average wind turbine would be lucky to turn 10% of the wind energy required to drive it into electricity, it is only because the wind blows for free that anyone would even consider it as an electrical energy producer.
T1 Terry
After 20 years living on a yacht I would take a wind generator over solar any day. (Just like I would have radar over GPS.) Of course the nature of the environment is totally different but the use of wind power for RVs is one that should not be overlooked.
Noise and vibration are no longer a problem, (some - not all), and with future developments the size and stow-ability should become less of an issue.
The RV market is huge and any manufacturer who can tap into it will be on a winner. Something that can fold down like a satellite dish is what is needed.
Captain Ron
Not a lot of trees around a yacht to mess up the smooth air flow Captain Ron, but a lot of shade I'd imagine wink
Not being a sailor person I ask this question out of possible ignorance on my part, but as a matter of interest though, when under way sailing ahead of the wind, what wind speed is available to drive the wind turbine? Wouldn't the turbine being travelling at the same speed as the yacht and wouldn't the yacht be travelling at the same speed as the wind? That would mean no wind speed to drive the wind turbine wouldn't it?
T1 Terry
-- Edited by T1 Terry on Monday 19th of February 2018 11:46:02 AM
T1 Terry
 In a marina and surrounded by hundreds of masts - the wind genny still works!!
Only while sailing downwind does the speed of the yacht reduce the speed of the wind over the wind generator and in light conditions, as you surmised, the generator becomes ineffective. Any wind forward of the beam can be added to the wind speed as the 'apparent' angle changes and increases the airflow at the generator. (Whereas the 'true' wind speed might be 10 knots the speed of the yacht makes it 'appear' stronger.) The time that a yacht needs the most power is at night when lights and other aids are employed - solar panels are then useless. Then come those endless days of overcast, rain and squalls - here, the wind genny is a god send.
Overall the wind generator was the more consistent and efficient supplier of power. On the occasions when I was forced to live without it, (usually some errant bird committing hari kari in the blades) it was like loosing a leg.
Captain Ron
Thankyou Ron, Homeless has a wind generator for his house boat that he keeps annoying me to connected up for him, so sounds like I should extract the digit and do it. He has plenty of solar (around 2kW from memory) and 400Ah of lithium batteries, but the houseboat is now full 240vac and no gas at all. It is a vertical mount type rather than the normal horizontal mount commonly seen, there are a few of those around the marina but all tied up because of the noise and vibration problems.
There is another one at an off grid house system we are updating, the noise and shake of the pole when it gets wound up is not something I'd enjoy living with and it is at least 100 mtrs from the house.
T1 Terry
T1 Terry
 Marinas often have an across the board ban on using wind generators because of the noise that some (not all) make - but if you are in a marina you have shore power anyway. Vibration is usually a balance/installation problem. Mine was noisy when it really cranked up, but was forgiven for the, up to, 35 amps it would put out. The noise problem has been well and truly addressed by a few manufacturers making them almost silent.
The attached photo shows the condition of my yacht rounding Cape Horn after being capsized 380 miles to the west. The solar panels were destroyed. The wind generator, even after being completely submerged and having all its blades broken off to about one third their length was still churning out 10 amps and played a large part in me being able to get the boat to safety without calling for assistance. Talk about vibration!!!!!!!!!!
Captain Ron
yep, you was knocked down
blaze
doh fear.gif Glad I'm sticking with land based and river based travelling, turning turtle would have similar results but at least if I lived through it I could walk away. That looks like something I'd prefer not to be part of even if I had a wind turbine wink
T1 Terry
