SmartBar Mackay Festival of Arts Floriade Darwin International Film Festival
Post Info TOPIC: Coromal Prinston Water system
Hi, Can anyone explain how the water system works on a Coromal Prinston
ie do you have to still use the pump when on town water ?
are the water tanks isolated from town water when town water attached
Cheers Ken & Lynn
You switch the 12 V pump off when on mains water. This applies to all vans. If you leave the pump on and the town water is lower in pressure you will pump from the tank, many have reported this happening. The two water systems flow through one way (non return) valves. This stops the mains feeding to the tank and also stops the 12 V pump emptying the water tank through the mains water hose inlet.
Scroll to the bottom of this link to the heading "4. Adding mains pressure and hot water." This shows how most van water systems are plumbed.
Could not expand on the sound advice that Peter has posted.
Jay&Dee
Hi Guy's thanks for the info, makes sense now  lol
Cheers Ken
