Post Info TOPIC: AGM v normal lead acid battery
Hi fellow travellers
My old ACDelco at $ 110AH battery has died.
Someone has suggested to go to a AGM battery at $140 extra plus I would need to upgrade my smart charger at $269.
My question is it worth the extra expense.
mgm
Need a bit more info
The battery Delco was it wet flooded starting battery or was it a deep cycle ??
What brand model of charger are /were u using ??
A multistage charger is better than the old school type . A big benefit is u can connect and forget them its all automatic .
Typically a AGM 100--130ah battery = 15-20amps for a single battery , 2 x 100/130ah agm at least 25amp charger
Repco 16 amp around 100 $
Projecta pro charger 100-200$ 15-21 amps www.ebay.com.au/i/122632025273
Mick,
Ask yourself a few questions before you decide.
1) Did the original battery provide the amount of power you needed for the time you needed it?
2) Has your power usage increased recently?
3) Will you be happy with the same system you had before?
If it was ok before, the same type of battery will be a suitable replacement.
If it ain't broken!!!
Robert.
Where is the battery mounted? Is the current one a flooded battery? (To most of us a "normal" normal battery for a van is a VRLA battery (valve regulated lead acid - which means an AGM or GEL battery.) If it is a flooded battery and in the cabin of the van it should not have been there in the first place. If it is in a compartment ventilated to the outside air then a flooded deep cycle battery will suffice, do NOT get a starting style battery, they don't work for very long in deep cycle applications.
Sorry for not putting all the info up to start with. My current battery is a Marine/RV Maintenance free Continuous use Deep cycle. And my charger is a Powersaver Switch mode Multi-stage as fitted by paramount in 2003. Both are in the front boot and the battery has a ventilated door.
mgm
Your original battery would seem to of lasted well, if you did not find any problems with it until it died why change, replace with the same type. The Marine/RV maintenance free battery is a good choice.
Dave
Considered Optima batteries. They have 3 ranges for different applications.
www.batteriesdirect.com.au/shop/search/510/optima.html
Thanks everyone for your thoughts. I have gone with the original battery and now have a solar panel to keep it topped up.
Cheers MgM
mgm
