Post Info TOPIC: Usefull ideas
Usefull ideas
these are some of the things i have done to my van for safety and security BAD489FE-D0E5-43B4-A01F-70622AB74265.jpeg
  Atherton tableland Nth Queensland. Currently have a Crusader Manhatton ,But in april 2017 will be trading it in on a Retreat Brampton.
You left out MIND THE GAP AND WATCH YOU DON'T SLIP.biggrin
Fellas,
Forgive my ignorance but why do people use a car stand or similar to prop the hitch when you have perfectly working legs on each corner of the van?
Larry
deverall11 wrote:
Fellas,
Larry
Hi Larry, those legs are not capable of supporting the draw bar load. They are simply stabilising legs.
Aussie Paul. smile
Wind down legs are steadys only, not supports. At home I use a stand under the A frame & remove the jockey wheel. Hopefully a deterent to the unprepared thief. The professionals would prpbably carry a jockey wheel & battery grinder. I recently saw a yacht in a front yard, & the owner removed the coupling from the trailer. Cheers Pete
I use axle stands to level the van, in combo with the jockey stand, then lower the stabilizers. I carry the axle stands around for servicing the wheel bearings.
