Post Info TOPIC: Removing step light
Removing step light
I have a small round dodgy LED light in the step well of my Jurgens. I can get the fascia and lens off but that's it. Do I have too break it to get it out or is there a way of getting it out without breaking it. Tried turning it and also levering it with a screw driver. No luck at this point.
Centrelink - Living the Dream.
Rusty, jurgens have a face book page if you ask the same question there i am pretty sure you will get an answer
A lot of new LED fittings are sealed, as such designed for complete replacement.  A picture might help to identify how to open it if its possible.
Assuming that most under the step lights are more or less the same
Can you let us all know how you removed it, Rusty
I tried to remove mine on a Jayco Conquest to change what I think is a normal globe, to a LED one
Did not have much luck, and stopped before I broke it
Just scripted a letter to Jurgens for sending in the New Year after lots of testing yesterday.
Like a lot of people on this forum, what I'd really like is the 12v wiring diagram for my van. I have 12v across the switch for the outside LED globe but only 3.5v across the switch for the stepwell globe even though they have a common (jumped) +ve connection (2 gang switch). The stepwell globe is causing my 12v regulator (Omegalec) to trip and I have to power it off & on again. Suspect that the LED globe is not good so crushing it to remove it may be necessary. Also not sure if it's a globe in a housing or it's all one unit. That's a question I have for Jurgens.
Can you disconnect the wires to it ? Yes ours is sealed donāt think same brand ?
 Cant disconnect and no idea what brand. That is actually my problem. Ill try Jurgens in the New Year.
