Post Info TOPIC: Thin Skin
Thin Skin
How do nomads attach fittings to the thin outer aluminum skin of their vans. I recently fitted anti flap brackets with 1/8" ally pop rivets and on the first test the batten hook caught on one  and almost ripped it off. On a couple I was lucky to strike the frame behind and they are firm.
Hi Willdoe,
Do a search for "peel rivets"
They open up like a banana peel when they are installed and you only need a standard pop rivet gun.
goo.gl/images/ERCXiQ
Travel Safely
Hi Willdoe.
As Dickodownunder has just mentioned the "Peel Rivets are good, however they may produce 3 small indentations from the rear as they set. They are ok if your material is reasonably thick, and they will crack fibreglass surfaces. I found out the hard way.
I have used the "Tri Fold" rivet throughout my van when I built it. They work the reverse to the Peel, as they fold out and concertina down when being set and form a flange being the surface.
I would suggest that you do a quick Google search and determine what best suits your situation.
Hope this helps.
Regards.
Hetho.
In Our old converted bus . The inner panels came out and we found any additions attached to outside had an alloy plate on inside . Either L bracket screwed or just sikoflexed depending on strength required ?
Unfortunately I can't get behind to fit backing plates. I think I will look into those trifold rivets as suggested by Hetho. Looks like 3/16" is the smallest diameter. Thanks For replies.
Willdoe
My Explorer has a pop riveted and sikoflexed alloy plate on outside to spread the contact area.
Willdoe
 The peel rivets wont dent the panel if the component that they are required to hold has a larger surface mounting area than the spread dimension of the rivet.
You can buy 1/8th inch peel rivets.
Travel Safely
Thanks guys ,i didn't realise such pop rivets existed .
You learn something new everyday.smilesmile
Blues man.
Be carful drilling into the outer skin in case of wires . I use a piece of copper tube only allowing a thickness of a match to go through the wall . As drilling through thin alloy when it bites it bites . I have seen a drill go through the outer skin and through cables and or the inner wall .
Dibs
gdyble
Dibs
 When drilling thru the walls I fit a depth limiter to the drill.
Drill a hole through an appropriate length of doweling or scrap timber. Put your drill bit through it with just a little bit of drill protruding.  The dowling stops the drill going in too far.
A bit of tape over the surface being drilled stops you scratching off any surface paint or whatever.
Aus-Kiwi has the right idea, spread the load, a plate Sika-flexed in position can do that, or a backing plate, or a rib structure.
