Post Info TOPIC: Fuel overflow
Fuel overflow
Hi Peps, I have an issue when and only when i fill up my motorhome with fuel, its a fiat ducato 3lt Jayco Conquest, even if i stop filling at first click it overflows from underneath, you end up with about 2 litres on the ground  no overflow when i half or 3 quarter fill tank.Any help much appreciated... thanks
Between the seats lift the square opening which allows access to the top of fuel tank check all the fittings etc for leaks
Dragonfly1
C Geyer
Hi Bob
If for any reason you are not successful in repairing the leak, then go to a mechanic
If it leaks when filling the tank, (with the vehicle on flat ground), then it will certainly be leaking when going up or down, a steep hill
Eventually the leaking diesel under the chassis, may be blown onto the exhaust, by the generated wind while travelling, this could eventually result in a fire
Also leaking diesel has been known to destroy the bitumen
Hope that this info is useful to you
Hi smile
Bad news and a real fire risk etc.
My suggestion would be to look for a breather hose that has come off a fitting on top of the tank. Perhaps look in the hatch mentioned or you can get your head in there or even a mirror and a light. ( NOT A MATCH furious) If not get a mechanic or similar to find it. Possibly just to reconnect it. Or just possibly someone has drilled a hole in the tank top when fitting something. The dust will stick to the diesel spilt so you will see the trail easily I think.hmm
good luck Jaahn
-- Edited by Jaahn on Monday 20th of November 2017 02:35:14 PM
Tony, Diesel or petrol leaking onto a hot exhaust will not combust unless a spark is introduced into the mix.
Thanks for that info, Patrol03
I learned something new today
But...
I stick with my original answer, of leaking diesel could cause a fire, just to be on the safe side
It was something they drummed into me as a 16 year old, in the English coalmines, learning about underground diesel locomotives
 Absolutely correct. Years ago we were traveling down the Bruce Hwy doing 100kph behind a scrap metal truck. A piece of metal dropped onto the road in front of us & bounced up underneath our car.
It punctured our fuel tank & about 30 ltrs of fuel came our of the rear in a cloud of vapor. It also ripped our exhaust system out. Luckily there was no BOOM!
You need to see a mechanic, soon.
Cheers Keith & Judy
Many thanks to everyone on your suggestions, back home now and will be following up on this matter, will advise as soon as issue is resolved...cheers
