SmartBar
Post Info TOPIC: Water Bladder
Water Bladder
I am looking at doing a bit of free camping and was wondering if anyone has had experience with one of these water bladders.
http://www.fleximake.com.au/Home/EachPr ... 848f8813f1
It fits behind the front seats and holds about 100 litres. I thought this would be easier than carrying large water containers and could be pumped into the van tanks by means of a 12v pump. I was wondering about the likelihood of springing a leak and flooding the car.
Any thoughts and stories of your experiences with these would be appreciated.
Rod
We have a 100L bladder for extended free camping in one spot.  Exactly as you said, every time we go for a drive, into town shopping etc we fill it to bring back to the van.
I have a 12v pump set up to transfer the water into the van quickly.
They are very strong, provided you keep sharp objects away it will last you for years.
Cheers Neil
Neil & Lynne
Pinjarra
Western Australia
Rod
G,day Rod,  we have the same bladder, & exactly as Delta18 says they work perfectly. We wrap ours in an old doona to protect it from anything that might damage it when in use...
It sounds like the answer to my problem. Thanks for the info!
Rod
I have the same fitted but I plumbed it to the towbar for ease of filling. Then conected from tow hitch to T conector on van pump. This way I can choose to have van tanks empty (180kg lighter) & (and ute 100kg heavier) have been doing this full time for 2years now.
Greet everyone as a friend, its up to them to prove you wrong.
Hi. We often used MARINE. Diesel and Water bladders.
Bouncing
olling\banging round for yrs.In some atrocious seas.
Constantly. for days\weeks at a time.
My last 2 were over 12 yrs old. never a problem.
Still have a 50ltr water here. "Plastimo".
THEY were the ONLY ones that didn't taint the inner bladder
over any period of time.
More exxy. Better quality. Probably same nowadays.
I have a Flexi tank done 20 od 000 ks full never lost a drop best tank out there as far as I'm concerned
Dibs
gdyble
Thanks everyone. I think I will get the Fleximake one and plumb in a pump.
