Post Info TOPIC: Home-built machine-make a 110 V AC electrical part
I am building a machine to manufacture optical components. The source of mechanical power is a 1/4 HP motor that's plugged into 110 V AC. Various parts of the machine receive mechanical power via belts and pulleys. The machine is a large square-ish box made of plywood. Inside it, there's the powerhead module containing the motor, hooked up to the machine via belts.
Grinding / polishing the optical components takes place on top of the machine. The process can be occasionally messy, with water-based slurry droplets being sometimes splashed over the top side.
Here are some images of previous machines made by other folks. The front/right/outside:
enter image description here
The back/inside, with the powerhead module, and the motor almost completely hidden behind the central plate of the powerhead (see the AC cable going to the motor over that plate):
I want to do the 110 V AC part "nice", or "by the book". Near the front/right corner (closest to camera in the first image) I want to add a panel (a small box), jutting out of the big box, containing: the main AC switch, a 16x2 LCD and microcontroller, and perhaps a circuit breaker.
I want the main AC cord to go inside the machine, lay close to the bottom edge back-to-front, then up the front/right edge, come out of the box through a hole, and into the front panel. There, it should go into the main AC switch. From there, it should split in two:
One branch should go into the circuit breaker, then back into the big box through a hole, and then into a regular 110 V AC wall socket mounted inside the big box. The powerhead should plug into that internal 110 V socket, for easy removal (the pulleys on the powerhead need to be adjusted or changed periodically).
The other branch should go into a 5 V "wall wart" supply, and then into the microcontroller connected to the LCD display. All of this branch should stay inside the front panel.
I've done lots of low-voltage electronics design, analog and digital. But I have very limited experience with mains voltage AC, building "to code", etc.
I assume there are some rules to follow when designing the AC part for a machine like this, but what are those rules? In terms of parts and components - should the internal AC wall socket be contained in a box of sorts? Should I run the AC cables inside conduits? (and what kind?)
I assume the rules can't be too different from building a house "to code".
The things to worry about are
1) strain relief;
2) having an appropriately rated and sized fuse or circuit breaker;
3) having a large, easily-operated, within reach of the operator, power on-off switch(http://www.kynix.com/Detail/19047/5511MGRYRED.html);
4) making sure everything is properly grounded; and
5) appropriate use of conduit for fire and abrasion protection. Use a C13-style connector mounted on the side of the unit and a standard power cord if the device is portable, or conduit if nonportable. An internal AC receptacle should be enclosed in a standard metal box.
Cannot help you with tips etc but question why you are using 110Vac and not 240Vac or evn 12Vdc with a brushless motor that is ultra efficient?
ps...back in the 70's I started grinding a 6" lens for a reflector telescope....started but never finished.
Kingblert,
I am guessing you may be in America. Is that correct?
This is an Australian site, so 110vAC information may ne a bit thin on the ground (we use 240vAC)
Others here may still be able to provide some information that you can use.
Regards Ian
