Post Info TOPIC: Desk top fan
Desk top fan
Can anybody tell me why a 600watt inverter wont run a 50watt fan. Battery is fully charged.
Is the inverter switched on?
Does it work with anything else?
Cheers, John.
Might have to connect another load to trigger the inverter into providing an output. They some times need a reasonable load to start up.
Alternatively, if it is a Modified Square Wave inverter, electric motors do not like them, as a general statement. Make sure the fan is set to highest speed and try again.
Also good to plug in something like a desk lamp to check is the inverter is putting out.
Iza
Iza
Iza
 That does not mean any desk lamp. It needs to be one with a 40 W incandescent globe.
I Have a cheap 150 or 300w? Inverter. (for yonk's).
It runs the std 12\15in Household fans in van from Solar\2 x 100a AGM's.
With lights and Teev\Box. Waterpump.
Around 12\14 yrs now.
Just the std $25 Woolies\Coles fans.
Skinny wiring maybe?.
-- Edited by macka17 on Saturday 4th of November 2017 07:28:15 PM
My inverter (2000W) also will not run our fan so we only use fan in CPs. Must be the fan motor design I reckon. No one could tell me why it would not run this particular fan but electrician thought it was the cheap inverter design or the cheap fan motor design. (I'm a cheapskate). Apart from the fan, our inverter will run everything else.
Good Luck.
Good Luck.
 Me too hako.biggrin
Aussie Paul. smile
