Post Info TOPIC: Mains water
Mains water
We have an Avan Ovation 7metre Motor Home Water from mains tap will not go into van? any suggestions please
Peter Day
Why not give the Avan people a call.smile
Santa.
If you screw, clip, supply line on.
It could be a sealed system.
Try turning on the sink COLD tap.
relieve the pressure??.
It has worked before
Peter Day
They are hopeless he avan mob
-- Edited by Daydream on Sunday 8th of October 2017 10:47:34 PM
Peter Day
 Please explain yourself. I have no idea of what you can not do from that.
Water won't go into van from mains water tap but will work from pump
Peter Day
Crikey DD, you don't believe in wasting wordsconfuse
As I said earlier, get some expert advice, if Avan cant/wont help you talk to another RV dealer, I'm sure it's not a complex problem, probably a stuck valve or similar.smile
Santa.
Ok thanks Santa will do
Peter Day
This is a stupid suggestion I know but I have seen it where people using a garden hose with a stop valve on one end have connected it backwards to the mains tap.
Good Luck.
Thanks everyone I have fixed the problem The non return valve was stuck I took it apart and blew through it then it worked
Peter Day
 wink
Santa.
