Post Info TOPIC: Meter to show hall effect signal..
How do I show on a meter with one of these?
http://www.ebay.com.au/itm/G1-2-G3-4-DN20mm-Full-Copper-Hall-Effect-Liquid-Water-Flow-Sensor-Switch-Meter-/252856678214?var=&hash=item3adf6eb746:m:mg8E2wuGXWV7WHg3AdThy2A
Aussie Paul. smile
I would ask them the question Paul, if they sold a meter for their flow sensor, as it has an electrical connector, on the end of the wires
Under the heading "Features" I see:
Three wire connection: Red for positive pole, black for negative pole, yellow for pulse signal.
It looks like you need a pulse counter. Once you have that you will then need to calibrate the device. I think you will have to build you own readout.
Search Water flow meter on ebay & their is several digital flow meters complete for around $40. Mutch easier than trying to build & calibrate a pulse counter for the flow meter.
D.L.Bishop
Futurelect sell flow meters with digital readout for around $35. Topargee also sell them but a little dearer at around $100. I installed the Futurelec model in my Aliner, they are excellent and extremely accurate.
