Post Info TOPIC: Aircomander Ibis air conditioner
Any suggestions why our air con has decided not to work at all - it is just dead as.  Any suggestions please
s.e.broad
The compressor died on our after  years. Had to get it replaced.
 Have you checked that power is getting to the unit, is there a separate Circuit breaker in your van, just for the Aircon ?
K.J.
From Coast to Coast, We'll see it all.......One Day
U.H.F  CH  18 /40  Say G'day.
Thank you
s.e.broad
Did someone let the smoke out? smile
Cheers, John.
ALSO.
There's normally a "separate" power plug at end of the cable from Air cond???.
In my last Roadstar. It was inside the storage area over dual wheel arch at end.
A double. Air cond and Fridge.
Anytime you put something in. It was easy to knock to off.
Till I shifted it.
IF it has calked. and you have the room.
Replace with a Household split unit.
100 times better at the job. Fraction of price. and more economical. QUIETER... To run.
We have just had ours repaired, for the same problem, no power. It was a blown transformer. The transformer feeds low voltage to the control panel. Total cost $130.
 Is there any lights on at all. Or is there a light on but nothing happening
Welcome to the gang Broads, enjoy here and out in the playground.
You probably did this first but have you checked fuses? Sometin=mes things are the simplist of things.
I have that problem a lot Rocket.....The lights on but no one is home biggrin
Sorry Broads, not like me to go off topic, no way disbeliefnobiggrin
No lights on.......no nothing!
s.e.broad
Thanks will get this checked out.......cheaper than  a whole new unit for sure!!
s.e.broad
Thats a shame. If one light is on , we sometimes can change the setting from 25 to 21 or air con. To fan etc. n that works but if no lights can only think of fuse as doug said. Best to get in a professional. Regards
Bumpy Roads??.
Maybe one wire shook out of plug.
