Post Info TOPIC: I have written a few books.
Being one of Australia's "brilliant", but, as yet, undiscovered writers, a friend put a PDF (?) on one of my books.
How do I remove it, please.
I need to add to "When CO-ORD was King". This book is of my time on roadtrains in the NT, Qld. and WA.
Regards.
Pipes
I am usualy fairly good at that sort of thing. Can you clarify what you mean? Are you saying they converted your text file to a PDF and now you want to edit it ?
And I somehow rather fancy that I'd like to change with Clancy ..
I like writing books. But with a PDF, I am unable to add anymore stories. The PDF, whatever it is prevents any more work.
Pipes
resave as a word doc, open file and go to save as and choose word doc from the file type selection
blazze
Pipes "your friend" should still have the original file you created. To save as a PDF (portable document format) he would have used "save as" which would have left your original copy untouched
Not really sure if you can save a PDF as a word document with Adobe Reader, but you can with a full version of Adobe Acrobat
Have sent you a PM pipes
JeffRae
Definitely who ever did the >PDF conversion should have left you with a text version. txt to PDF is a  bit like a prawn in the barbeque ... you cant "uncook it" . Well not easily any how.
 No you can not edit with a reader. If you are going to stick to Adobe software you will need to purchase the Adobe suit.
Pipes, did your friend save the PDF file with a password. If not then it is able to be edited. There are plenty of free PDF software. Here is a list of PDF software. Read through this and try some of the freebies.
I note both LibreOffice and OpenOffice have the capability to possible do the job you require. I would suggest starting with LibreOffice as it is more developed than OpenOffice. Once you have converted the book into a word processor document I suggest you do your editing in LibreOffice Writer. When you have finished the editing save the document as a word processor file. Then also save it as a PDF file. Use the PDF file as the copy you will share. Doing things that way will maintain control of your original document as well as sharing it in a format that others can
Pipes, further to what I said above, in the link I provided you will see free software that you can use like a word processor. You can create documents, save them for distribution and amend them at a future date in that software.
Use a converter to convert it to whatever you like. Converters are avaiable free on the internet, do a search 'free PDF to ??? converter'.
Did you get this sorted @pipes
Hi Pipes ..
I certainly enjoyed reading the stories that you sent me a few years ago.
RE the inability to modify the PDF files.
I recently downloaded a free program that is supposed to allow you to do this.  (Able Word)
I haven't used it yet but it looks as though it opens the 'PDF' file as a word doc' or similar & away you go.
Here's  link to Able Word that can write to PDF files
http://www.ableword.net/
-- Edited by Cupie on Monday 11th of September 2017 10:37:07 PM
-- Edited by Cupie on Tuesday 12th of September 2017 01:41:33 PM
