Post Info TOPIC: Instrument cluster removal
no
We need to change a bulb on a dashboard on a 2002 sr5 hilux anyone know how to remove the instrument cluster?
regards
GG
boxing kangaroo
Take it to an Auto Electrician. If you botch the job yourself it will cost you around $2,500-$3,000 for a new cluster. Not a DIY job.
Cheers Keith & Judy
Search on YouTube. I'm sure you'll find it there.
Or try some of the Toyota or dedicated Hilux forums which will usually offer sound advice if the subject has been covered before.
Travel Safely
To build a car, a light globe is hung from a sky-hook travelling along a line. Then the dash is built around that and then the car is built around the dash. At least that the way it seems when you try to replace a dash globe or a speaker.
Centrelink - Living the Dream.
They are generally quite easy to remove, particularly now with the electronic speedo (no speedo cable)
Try this site https://www.yotatech.com/forums/f116/sr5-gauge-cluster-swap-how-pics-179106/ it should guide you through it.
A big hammer will fix it.
Then you can go out and buy a proper ute.
Shhh I didn't say that.
