Post Info TOPIC: Oil Usage Toyota Landcruiser 100 series
My 100 series Toyota Turbo Diesel Landcruiser 1999 model , it using a litre of oil per 1000klms and is not blowing smoke
Thoughts on the subject, Please.
keep driving it
blaze
From what I read on other forums this has been a common problem with the v8 diesel and more than a few motors have been wrecked by owners that did not check there oil level on a regular basis. Just make sure you don't let it get to low and discus it with your mechanic at the next service.
My GU Patrol 2002. ran 246k. km's mainly towing 6.5 mtr van.
NEVER used a drop between 10k services in it's life.
2010 D-Max (also 3 ltr) 91k, kms today. Also nothing between changes.
Older machinery was designed to USE oils in general running.
Big. old. sloppy, Pots and valves.
Much tighter tolerances. Better materials, design.
They tend not to anymore.
Apart from Toyota engines. They has a reputation of slurping it.
Always have.
Plus Full Synthetics give much better Lubricity, and longer life
at those tolerances.
You will have the 1HD-FTE 6 cylinder turbocharged engine. Your best bet is to go to http://www.lcool.org/index.html  then have a look around and join the forum to ask your question from those who have been there before. They are a great group and very helpful.
Good Luck.
What Hako said..
lcool forum is very helpful I have a 2006 100 series turbo diesel and does not use oil
the 6 cyls are a very good motor
Thanks Guys for your ideas
-- Edited by Renrut on Tuesday 29th of August 2017 03:46:53 PM
It's either burning it or leaking. Have you tried a higher grade fully synthetic?
