Post Info TOPIC: Mchitch coupling
Mchitch coupling
Thinking of getting one of these , mainly to allow us to lift the front of the van up to level - current towball hitch would hit tail gate , looks like Mchitch would let us raise Hayman Reese up by about 70 mm
http://www.mchitch.com.au/_p/prd1/3762580191/product/3.5-tonne-%22easy-fit'-caravan-automatic-coupler
HAPPINESS is a journey, not a destination. So work like you don't need the money, Sing like no-one is listening, Love like you've never been hurt & Dance like no one's watching
Hey mate why are they good
compaird to a normal tow hitch
thanks
d
thanks
 they are not as  high , 125mm compared to ~ 220 mm ....
You can watch a video about them, if we were changing we would get one
youtu.be/bZAR6yQxaE8
What a great jigga that is
we are looking at a new ( second hand) off road van
and I think the mark 3 will have to be on top of the list
thanks guys
d
We had a mchitch auto coupling found ok but had to change to Easy-Hitch and find it much easier to use . At solid coupling check it out on the web
thanks guys
 Humm..
Why not look at a DO35 0r DO45 depending on your vans ATM. Better for off road.
Also hitch closer to tug and read or clears hitch. Well does nicely with my Patrol.
We sold our Auto Mchitch as have 2 friends, hitching up is perhaps easier but unless both car and van are on the same plane unhitching in far to hard, and giving that its for off road its unlikely that they will be level.
Cheers.
If you need to use a WDH then a DO35 is a standard fit up.
With a McHitch you may need rollers as an extra to have them work properly.
Do some research as to your personal needs before laying down your hard earned on the hitch.
Travel Safely
 The DO35 was my initial choice , then started looking at the Mchitch , have now gone back to the DO35 as the Mchitch requires adaptor welded to WDH head
 Yes lizard, I was thinking the same as you but then opted for the D0 35.
Another point is that the latter does not extend the pivot point rearward quite as far as the Mchitch.
Travel Safely
