Post Info TOPIC: TAIL LIGHT HELP
TAIL LIGHT HELP
I need to remove my tail lights on the camper. They are LED AUTOLAMPS 80Series Triple.
I need to get into the void space behind the lights. There is a Hand size Service hole behind the light fitting. Behind is a Void with no access from the inside of the van.
The lights are screwed on with Self Tappers that are accessed by removing the Red and  Amber lenses.
Thing is I have forgotton which way the Tabs are for removing the individual LED Lamp units.   Are the (tabs) on the sides, left / right or at top and bottom when you try to prise them off.  Tried "Gently" with various tools to prise them out but not had any success.  Would be great to know which edges the Tabe are on, be they Top/Bottom  or  Left/Right.
As a Datum/Ref point  I have all the three LED units RED and AMBER LENSES with the makers   www.ledautolamps.com    logo at the top.
Any advice would be halpful. I have emailed Autolamps today but probably they will not be in the office till Monday before I can get a reply.
Mike
-- Edited by elliemike on Friday 21st of July 2017 10:24:38 PM
Mike & Ellie
Hi Mike
I would say from the inside as that type has 2 legs were you can screw a nut on
Maybe I am wrong
Good luck anyway
Regards John
They look the same as mine and are glued on.
if you go into the website you quote and look at the lights they have diagrams
of how to fit and it says after screwing base on to clip the lens in place
the drawings the show seem to indicate the would have tabs top and bottom centrally
located in all three sections
it is also possible they have been sealed with a bead of silastic which you would need to cut
with a blade
brian
with a blade
brian
 I actually installed them myself a few years ago and they just Clip in. I cant remember which edges to prise.
Mike & Ellie
Cruising Cruze wrote:
Hi Mike
Maybe I am wrong
Good luck anyway
Regards John
John they are screwed in from under the lenses with Self Tappers. That is why I want to remove the lenses so I can get at the self tappers to get into the void behind the lights.
Mike & Ellie
with a blade
brian
 Yes Brian done that mate and still cant determine which way to prise the tabs which edge are they on ?   Tried what I consider reasonable force (I fitted these units)  and am worried I will break them.
Mike & Ellie
Can you not get behind and remove the 10 mill nuts?
 No mate  they are screwed in from under the lenses with Self Tappers. That is why I want to remove the lenses so I can get at the self tappers to get into the "void" behind the lights.
Mike & Ellie
only other suggestion I have is try the closest Autopro outlet to you tomorrow
they are agents according to the link
brian
Sorry mike, just sharing a thought thats all.
Can you not get at the screw tips with a set of grips??
Ive broke many of these lanps at work trying to get them out.
Not at work till wednesday. Will look then for ya if thats any good.
Cheers.
Kezngaz.
brian
 I wil nip into Martins Trailers Tomorrow morning as that is where I bought them. I will look at their display units and ask them.
Brian, I actually am replacing the Clearance lights on the side of the van with LEDs. The two rear  clearance lights back onto the cavity  and I need to get into the cavity to adjust the wiring.   No access only with the  the Rear Stop Lights unit removed.
Mike & Ellie
The clips are on the short sides, but are extremely tight. My suggestion is to try using something thin like a credit card pushing it in as a screw driver is too thick! Hope the casing is not too brittle from age...
Glen
Don't tell the missus.
But dining table knives make light Narrow "levers".
for that sort of thing.
Just DON'T let her catch you OK.
Problem Sorted.
Had a look at the ones in a Trailer Parts place. Tabs are Top and bottom edge
The guy told me they can be very tight if there is a lot of  Red Dust in there.  Just work away at it.  used a  knife blade (thin marking knife) to pry in the joint then the Blade of an Engineers Square. Levering with the Eng's Square to release the Tab. Then  between using a marking knife and a small flat blade srewdriver  slowly easing the lens out, keeping leverage o0n the Eng's sqare.       Only one out of six was easy they were all cemented in with Red Dust. The easy one took about 4 minutes.   Talk about tight Trev.
Sorry no matter what I do to this picture  it wants to be upside down.
Thanks for the comments everyone.
-- Edited by elliemike on Saturday 22nd of July 2017 07:06:11 PM
Mike & Ellie
its good to hear when a solution is found
thanks
brian
Well done mike, and not one broken!!!
Hi Mike
Thanks for that info Mike
We keep on learning everyday never to old
Regards John
I've got\had a set on my 6x4.
They screw to trlr frame. and pop into their frame. top and bottom centre.
Thin flat blade screwdriver.
Their outer black frame "flexes" just enuff to allow then to pop out.
I've changed them to a set of "mini" 6 in long.1-1\2 high. 4 lights.
ONE piece block. If you run silicon round outer lip of lightcover\mount frame
and central cable hole.
They magic. Take up NO room for knocking off.
As my last Full. r\h one did.
Putting on rear of Ute Canopy, and van next.
