Post Info TOPIC: G & S Chassis Recall www.recalls.gov.ua
No automatic alt text available.
Any idea what its in relation with Possum3?
I wonder if 'Austrail' Chassis are on the recall list as I believe they are one now.
Gday....
Thanks Possum - I woz a bit late -
http://thegreynomads.activeboard.com/t63652472/cia-vic-applaud-positive-action-by-well-established-member/
{edit: from the link above - G & S Chassis manufacture over 4500 chassis per year and it was through their extensive experience that it came to their notice that a small number of early chassis (less than 0.5% of chassis produced) have exhibited a trailing arm weld failure.}
-- Edited by rockylizard on Wednesday 14th of June 2017 06:51:00 PM
Basically, No - I am uncertain of which manufacturers are involved - I noticed that there has been a lot of talk about serious caravan accidents and the ACCC is stepping up their vigilance on manufacturers. Although I believe the failures do go back to August 2016
There are several caravan owner sites that have some pretty disturbing pictures of their caravans.
The recall notice doesn't give much of (any) an idea of just how many there are likely to be found faulty.
confuse Possum (and everyone else?) read my earlier post -
"G & S Chassis manufacture over 4500 chassis per year and it was through their extensive experience that it came to their notice that a small number of early chassis (less than 0.5% of chassis produced) have exhibited a trailing arm weld failure."
By looking at the photos of the failure, It looks as though the wall thickness of the componants is too small. I am an engineer, and a welder by trade.Perhaps the later models have heavier componants. The welds are usually the strongest part of the thing. Failures are usually in the heat affected zone beside the weld. Its good to see a manufacturer back their products.
 I do believe that Lotus is one make that has this suspension.
It appears that the G$S problem was allegedly hoped to remain "low key" but the word is out.
The Al Ko recall at least lists all the van makes in the document.
https://www.productsafety.gov.au/recall/al-ko-international-pty-ltd-braked-axles-10-electric-fitted-to-caravans-and-camper-trailers
-- Edited by Dickodownunder on Thursday 15th of June 2017 07:31:17 AM
Travel Safely
You may be right Bill12, It seem that the rework is to weld a strengthening gusset plate over the section.
Dunno about Gussett over that job.
Looks pretty light on tubing. (Even if H\T Steel.)
for a suspension swinging arm section.
They take all the weight and stresses from the bouncing.
Unless on Underwater welds and water friction.
I've never seen the sense in grinding down welds.
I like to see a nice run anywhere.
some are beautiful works of art.
rockylizard wrote:
Gday....
John  That failure rate you quote is high in engineering terms,,,, 1 in up to 200 will fail. TOTALLY UNACCEPTABLE.
 I'll bet someone else found the problem and someone has squealed and made public,,, this is how recalls surface in public domain.
-- Edited by Baz421 on Thursday 15th of June 2017 05:10:41 PM
