Post Info TOPIC: Gas Supply and Flue Restrictions under window - AS5601.2 2013
Could any gas fitter or plumber advise the requirements for gas heater flue under an opening window of a caravan - preferably quoting the reference to AS5601.2 2013
500mm to the side or below any opening into the caravan.
AS5601 figure 5.3
That would probably pre date 2013.
I have no gas expertise, but did check all this stuff when I built the OKA.
-- Edited by Peter_n_Margaret on Sunday 30th of April 2017 05:13:57 PM
That's what I thought Peter, Thanks - but to get a copy of the Aust Standard is proving difficult my water heater flue is directly below window so fumes coming in sleeping area if I heat on gas.
Possum 3
I cannot provide the requirements, however I can give you are example. We have 23' Jayco Outback with full slide out. Consequently the gas heater has been placed under the seat on the door side of the van.
The flue is under the window that is obstructed by the door when it is open. The plumber was required to install a kill switch on the gas unit that connected to the window. So in situation if the window was open and the gas heater on the switch will close down the heater. We needed this requirement to enable a plumbers certificate to be issued.
May be of some help.
JohnR
"House sitting Barmedman NSW"
caravansplus have some information on gas installations for caravans and mobile homes, also a link to reg's from office of gas safety.
Try this link.
www.caravansplus.com.au/pdf/Guide%20to%20Gas%20Installations%20in%20Caravans%20&%20Mobile%20Homes.pdf
Hope this might help. Rob.
Try this link.
[link fixed - Cheers - John]
-- Edited by rockylizard on Monday 1st of May 2017 08:42:01 PM
Thanks John.
Cheers Rob.
